Request VIN Lookup Thread
It's never gotten an update released to it, I've found a few others online with similar vins and being on the same sync 4a 4.0.22277 and no updates. Sync indicates it's "up to date"
If there is no active OTA trigger pending for the vehicle, it will always say it is up to date (or show the info of the last update it got if it got one). You can't guide yourself by that. This pdf from Ford shows what each vehicle's latest Sync version should be based on year and platform and is mostly accurate.
KSUcat
Eric
Kansas
2021 F-150 Powerboost Limited
Can someone check my VIN for pending updates (or the latest that I received)? Got in the truck a couple times lately and had the gauges and My View go back to default, like I received an update but Ford Pass doesn't indicate anything since 3/14.
1FTFW1ED6MFB78296
Thanks
shalabama
JC
North Alabama
2021 F150 Lariat
1FTFW1ED6MFB78296
Thanks
Had the same thing happen to me recently. Expected to see notification of a new update that I received but found nothing on screen or Ford Pass. Puzzling what could be the trigger for the change without an update.
DanTerepka
Dan
Atlanta Ga
2021 F150 Platinum
Can some one check Module Updates and OTA ?
1FTFW1E82MFA71779
I updated using FRDS abut 6-9 months ago and am wondering if its worth renting it for the weekend and doing it again.
Thanks In advance!
Kutch
Matt
Poynette WI
2021 F-150
Military
1FTEW1EP8MFB76412
Audio 23-PU1024-6CHAUD
Don’t know if the update can be rolled back or not.
Thank you!
Can you look up my bin in both systems?
1FTFW1E8XMFB83486
The only OTA you got was 24-PU0223-VI-RBS just yesterday. It is believed that update if to open the door for more updates to start coming in for vehicle on Sync 23159 like yours. Hopefully you start getting more sooner than later. I don't have access to FDRS until later, but this is what PTS shows you have pending.
Ford F-150 Request VIN Lookup Thread 1713888927981-rx
1FTFW1ED6MFB78296
Thanks
Last OTA you got was 22-PU1009-TLC-CSM2 on 3/14 and nothing has been sent since then. The myview resetting happens to a lot of trucks even mine. There is no fix that I know if for that yet.
1FTFW1E82MFA71779
Thanks In advance!
Due to the Sync version you're on, remind me after 7pm eastern when I have access to FDRS to check your VIN there. What I want to look for I cannot see with PTS.
1FTEW1EP8MFB76412
Thank you!
It can be rolled back, but I can't help you with that. I would message Jesse-Infotainment for to see if he can help you with that. It will require allowing him remote access to your laptop while the truck is connected with FORScan. If this is something you are comfortable with and you have FORScan, then message him. Otherwise, get FORScan first and then reach out.
DigitalG
Tim
Wetumpka, Alabama
2012 Ford F150 Harley Davidson 4x4; 2019 Lincoln Nautilus Reserve AWD; 2019 Toyota CH-R; 2020 Tracker Off-Road LX4
Wounded Warrior Social Worker; Retired from US Air Force
Could I get someone to run my VIN in PTS/FDRS for my '22 F350 King Ranch. I've had the truck for 2 years now and have not received a single update. Have inquired with my local Ford dealership during previous service appointments/recalls and they continue to say my truck is up to date. Sure would appreciate it!
VIN lookup request: 1FT8W3BT7NEC56057
I have a service appointment tomorrow morning (powertrain issue, inop camera) and will attempt to add the update issue to the list. Thank you!
I'd be happy to check, but I don't have access to FDRS until I get home from work. Remind me after7pm eastern, as my memory is not my best asset. PTS shows what you already know; no OTA history at all on your truck and you're on Sync 21136 which is very old software at this point.
DigitalG
Tim
Wetumpka, Alabama
Will do! Thanks!
PeteyGRK777
Eli
2021 F150 Powerboost
Best thing to do is go the FDRS/MONGOOSE route and DIY it. Or your waiting a long time. You have a full weekend of updates from what is showing. And how many more after these are done is unknown.
Received an update finally! 24-PU0223-VI-RBS, supposed to be a good sign or something (y)
Thanks!
DigitalG
Tim
Wetumpka, Alabama
Good evening! Reminder you asked for...
You're showing a pending GWM update, so that's good. Everything seems fine as far as your truck is concerned. No way to predict when you will get an OTA, but everything is lined up for you to get them.
Ford F-150 Request VIN Lookup Thread 1713917896125-wr
dgndgb
United States
2022 F150 Powerboost Lariat
Your truck seems to be favored by the OTA gods and looks like you've gotten all of them. You are only showing an HVAC, PSCM and IPMA update.
I went ahead and updated all modules as I had some free time last weekend.
For those that see this IPMA update, beware it was about a three hour update for me. I don't know if it's wishful thinking but it feels like lane centering is working better now when using Bluecruise passing semis. Not sure how to verify but the ping-pong type effect seems to be much better.
HVAC updated successfully but still shows in FDRS and I had two phantom updates since as well.
DigitalG
Tim
Wetumpka, Alabama
I've seen some recommendations to have Ford reprogram the Gateway Module indicating this could/would trigger updates to start rolling in. What is your opinion?
It seems weird that I've owned the truck for 2 years with absolutely no OTA updates.
