Request VIN Lookup Thread
Big Dog Daddy
New Jersey
Definitely ready to not drive this death trap they call a service loaner anymore and get back into my truck after 87 days.
LOL, my truck was at the dealer in early 22 for a month! I think that, that's the same Pinto that they gave me! Hopefully they did the exploding gas tank recall before you got it! :ROFLMAO: ?
Kanuck
Winnipeg, Manitoba
Retired Electrician
Up in Canada, this is what they give for loaners. This one needs a flat repair....lol:ROFLMAO::ROFLMAO::ROFLMAO:
Ford F-150 Request VIN Lookup Thread FB_IMG_1705025299809
Abraham5G
Abraham
Houston, TX
Could you please check mine? VIN is 1FTFW1E88PFC11614
TexasTea
Here
2021 F150 Tremor 402a
@rugedraw are you able to see why the new update keeps failing? I suspect bad battery but of course when I went for 30k service "oh it's fine".
Need something to put pressure on them with and obviously failing updates is a good one.
Thanks so much
1FTEW1E87MFC34390
rugedraw
Javier
Miami
Auto Sales
Thanks so much
1FTEW1E87MFC34390
Battery, battery and lastly, battery. Capacity is being recorded at 25 and it should be 70 with the OEM battery. Voltage is at 11 instad of 12, and SoC is at 43% instead of 80%-100%.
Ford F-150 Request VIN Lookup Thread 1705076105493
TexasTea
Here
Outstanding. This is what I need to get a new battery from the dealer.
rugedraw
Javier
Miami
Auto Sales
Not really. In order for warranty to cover the battery replacement, there is process that must be followed. It requires the dealer performing a Rotunda battery test which takes 2-3 hours. If the test fails, warranty will cover the battery.
beyeg
Montana
2023 F150 Platinum Powerboost
I posted this in another thread without seeing this thread first. I'll head over and update my other thread shortly.
Purchased my truck in late December (20th-ish).
Trying to learn as much as I can about the OTA status and other updates that it did or should have received.
VIN 1FTFW1EDXPFA05126
Thank you so much for help.
TexasTea
Here
Well. This should get them to at least test it. I'm not convinced at all that they did any battery testing when I took it for the 30k service despite me explicitly calling it out and asking for it. "Yeah it tested good"... Baloney.
Dduffy16
Derek
Marine Engineer
@rugedraw Having issues with the 4.3.4 update. Wondering if you could take a look at where I’m at. Thanks!
1FTFW1E8XMKD51022
rugedraw
Javier
Miami
Auto Sales
1FTFW1E8XMKD51022
It failed many times due to unsatisfactory battery condition. OTA like this one that require the vehicle to be inhibited have a 30 day timer to install. Once the 30 days are reached, the OTA trigger expires and you have to wait for it to be resent to your truck. In your case, the OTA trigger expired on 11/26 so you can ignore the message you are seeing on your truck. There is nothing you can do now but wait for it to be resent to you.
Ford F-150 Request VIN Lookup Thread 1705078936524
Dduffy16
Derek
Marine Engineer
Awesome. Seems like a common issue. Thanks for the help!
rugedraw
Javier
Miami
Auto Sales
Very common. When an OTA that requires the vehicle to be inhibited fails, 99% of the time it is due to the battery.
Numerous threads on here about batteries and you'll get run around by dealer not wanting to do warranty battery replacement. Less headache to just get the biggest aftermarket battery that will fit and move on. H8 for non-Powerboost and H7 for Powerboost. A good battery and your truck should have no issues with OTA battery failures.
TexasTea
Here
If they hassle me yeah, I'll just suck it up and do that. What a joke though about junk batteries being OEM...
