Request VIN Lookup Thread
Chaos150
Patrick
Corpus Christi
Operator
My vin is 1FTFW1E80MKD53460 I’m looking to see if there are any OTA updates. I keep getting the 2.8.1(not sure if that’s correct) update for the power lift gate. And it always fails.
rugedraw
Javier
Miami
Auto Sales
The next time you get this OTA sent to you, drive your truck for a good half hour to charge up the battery. Connect your truck to a battery charger in the evening and set the update to install at 4am after the truck has been on the charger for hours. The reason it failed for you and countless others is due to low battery voltage. This is a very common issue with this particular update.
Capt Obvious
Longwood, Fl
21 F150 Lariat SUper Crew 500a 3.5 EB Max Tow
No OTA history in the past 60 days and no OTA in queue at this time. The last OTA recorded in your history was back on 10/27/22, but I have no details as to which update that was since it was over 60 days ago.
I see no DTC's on your truck referring to the battery voltage being low. However, your truck is reporting DTC's for speaker 1-6 every time you drive it. It has been doing this for the past 60 days that the history is recorded.
Thanks man, I did change the all of the speakers about 1-1/2 years ago and added a plug and play Kicker Key setup with a Kicker Hideaway 10” sub. I didn’t change the speakers until after the installation because I blew a back one so I upgraded them all. Must be running through the key causing that.
rugedraw
Javier
Miami
Auto Sales
That makes sense. Disregard then.
Burner
Andrew
Jacksonville, FL
2021 F-150
Navy
I've had my truck in the shop all week and gotten no updates. Going on 6 weeks of dealer blue cruise troubleshooting but they finally received a new APIM and I dropped it back off. Can anyone check my VIN to see if they're actually making any progress? They're terrible when it comes to giving me updates
1FTFW1ED6MFB67945
Capt Obvious
Longwood, Fl
Ahh, just thinking maybe it’s because I have the center dash speaker disconnected, it sounded pretty bad after tubing the Key.
Hey thanks again for looking these up for everyone.
jwillafo
Eastern Shore of Virginia
2021 F150 XLT 5.0 SCREW, 2017 F150 XLT 5.0 SCREW
Just curious if someone could check FDRS for any pending OTA updates for my 2021 F150. Local dealership recently confirmed OTA failure and said they updated APIM and TCM.
1FTFW1E50MFB76262
SYNC 4, Software Version 22087_PRODUCT Revision: 415
Thanks
rack04
Justin
2021 Ford F-150 Powerboost
A quick look at my VIN for updates would be appreciated. 1FTFW1ED6MFB86236. Received a OTA update yesterday and trying to determine if that gets me all updated. Thanks in advance.
rugedraw
Javier
Miami
Auto Sales
1FTFW1ED6MFB67945
They are working on your truck, but have not started performing updates yet. The are running PMI's that I assume are to program the new APIM, and doing some camera and IPMA alignments.
1FTFW1E50MFB76262
Thanks
You have 2.6.0 in your queue for the 4th time now. It failed the previous three times it was sent to you. Error code reads:
"groupId":"1""errorCode":"ManifestCurrentAssemblyDoesNotMatchWithFromAssemblyInManifest(14)"
This update is for both the APIM and TCU. I see in your history that they successfully updated your APIM, but the TCU update shows that it failed. Because they only did one of the two, I doubt the OTA will be successful because it is a two part update and once it sees your APIM is up to date, it won't bother going through the process and updating the TCU. 2.6.0 was sent to you yesterday, so it will be two weeks before it expires. I think you should ask your dealer to try to update the TCM again.
Yes, you are up to date.
jwillafo
rugedraw
Thank you for your time and the information. I just spoke with the dealership and they will "investigate" sometime next week.
JakeSM
Jake
Maryland
21 f150 XLT
In an attempt to keep the other threads clean lets use this thread to request VIN lookups from anyone with an active FDRS or PTS subscription.
Please specify if you are looking for OTA updates (done via PTS) or module updates (done via FDRS)
All 2022 truck owners are built from factory with all the updates with the exception of full screen CarPlay/Android auto and dual phone bluetooth connectivity
Here's some good OTA information courtesy of @JScaro
https://www.motorcraftservice.com/Home/SetCountry?returnUrl=/Purchase/ViewProduc
I, for one, think this is a GREAT idea.
When you ask for a VIN check, please specify if you are looking for OTA updates, or if you need to see what specific modules have updates pending on FDRS.
could anyone run my vin for OTA updates just to let me know what’s going on and what you can see? I have a job 1 truck. Vin is: 1FTFW1E8XMFA22488
rugedraw
Javier
Miami
Auto Sales
Sparks
US
2022 F150 Platinum & 2022 Bronco Outer Banks
I would appreciate it if someone could run my VIN 1FTFW1ED4NFB71168. I am taking the truck for a wiper motor recall this week and would like to know what updates I can have the tech install.
Thanks!
KDK
1FTEW1EP7MKD71408
I'm super frustrated I've not received the update to make AA fullscreen. It's all I have been wanting since the truck was released.
I have forscan and a reader, is their anyway to manually grab these updates from Ford and install? I have everything set to Auto download and update but nothing.
