Recommendations for a Bad Auxiliary Battery
tonyramz
Juan
2021 Ford F150 Powerboost
IT Manager
I am getting some variations on my battery monitor from 12.3 V when the truck is not on, to 14.5 V when the truck is being driven. I decided to check each battery individually by disconnecting them to check their charge and found that the auxiliary battery is bad. Any recommendations for a replacemen? Does it need to be an AGM battery?
Kodiak
Jmitchelltfo
Jeremy
Ozarks
2021 King Ranch PB
Range Ops
Cliff notes from most of the auxiliary battery threads.......
LFP provides more energy than a similarly sized AGM
Need to keep an eye on LFP when used in very cold climates, if your vehicle is stored outdoors. (This was not a problem for my LFP through several weeks with temps around -7°F )
-Parallel LFP setup is very easy with minimal modification needed to your battery cover. (X2 was $200 but has a 10-year free replacement at Batteries Plus)
-LFP replacement in OEM location will possibly require some modification to your battery box.
-Oreilly's or other AGM 12-14 AH replacement requires a little bit of Dremel work to fit. (Typically, a 90-day warranty on powersports batteries like these)
-OEM replacement.......you already know that isn't the best option since you're here looking.
tonyramz
tonyramz
Juan
IT Manager
Thank you for your replies and recommendations. I will certainly be getting a new battery today, probably the O’Reilly one since it is less than half a mile from my house.
For the record, I did disconnect both batteries and tested them as standalone. I noticed that when I tested the main battery it kept giving me a good battery but the numbers on the monitor did not lie.
Jmitchelltfo
Jeremy
Ozarks
2021 King Ranch PB
Range Ops
No matter what battery you choose, I would recommend a bluetooth monitor. It will help keep track of resting voltage and has some other nice features too.
This is the one that I bought after several recommendations in other threads.
https://www.amazon.com/ANCEL-BM300-...2906950&sprefix=bluetooth+batt,aps,308&sr=8-8
That's the specs of the batt -- it's not a fail for that batt. That's not a starting batt and it's fused for 125a.
UGADawg96
JAX, FL
Is that test tool not accurately reporting SOH of the little batt ?
No, the CCA is like 90 -- that's still connected to the 12v bus.
JEB
2021 F150 Lariat PB 502a
I have the same battery tester. Did you reset the specs for the smaller battery before running the test?
tonyramz
tonyramz
Juan
IT Manager
This is why I love this community. I went back and rechecked the settings and I had it set to 500 CCA on the test above. I changed it to 150, since I could not find the proper CCA on the battery and the first test indicated 127 CCA, and the results this time were 64% State of Health and it said Good - Passed. Thank you. I will continue to monitor it on the weekend to see how it is after several days of not putting the charger on the truck.
JEB
The correct setting for the aux battery is 90 CCA. Your results will improve at that setting.
kantonburg
Wesley
BV
2021 F-150 Lariat PB
That seems like a great option if you want the red Chinese knowing everything about you given all the reports of irrelevant data harvesting the app does. Caveat emptor.
Do you have a recommendation?
