BILDOZER
BILL
Seattle
2025 King Ranch Powerboost /2021 Ford F150 Laria t2.7.
Going to work.
Ok... So I just checked my 21 lariat which I purchased february this year. I kept having the radio presets page go from three to two pages every time I restarted the truck. After I pushed in the @ 75% loose fuses under the hood, the presets on the radia have remained... If only I could get the easy seat toggle back to disable the feature Id be golden!
dhrandy
Randy
Concord, NC
Engineering Tech
The ones under my hood weren't seated, every one of them pressed down further. The ones in the passenger compartment were fully seated.
JScaro
Georgia
2021 Ford F150 Lariat 501.5A
Beer Drinker
Mine needed a push, Thanks for the heads up.
PBXL
Somewhere
2021 F150 XL Powerboost
I didn't have any noticeable issues but I was already under the hood and decided to check my fuses and all were able to be pushed further in with a click.
Sapphire
Courtney
Chicago
2021 F-150 Powerboost Platinum (job 2)
I checked my fuses in the engine compartment today. None were in danger of falling out, but 46 of them seated in further.
Akademiksk16
Ken
2021 F-150 xlt
Just picked up a 21 scatpack and noticed that all the fuses needed to pushed in similar to the f150. maybe its a new thing with manufactures
UGADawg96
JAX, FL
I just checked my Nov 21 build and all the fuses here were fully seated.
Ford F-150 PSA: Check your fuses for full seating! 1639231373888
pkinneb
Paul
Zimmerman MN
3DogKnight
Minnesota
2020 Escape Titanium - 2021 F150 XLT
100% retired
I just checked my fuses and most were not fully seated. I haven't had any problems @1600 miles. So far. Build date of 9/20/21 Dearborn plant.
3DogKnight
Minnesota
100% retired
Cool. I haven't had any issues either though I don't have as many miles yet. Sounds like "If it ain't broke, don't fix it" would apply here.
But preventive measures are worth the effort.
houstongoose
Aaron
2021 F150 Lariat 3.5 EcoBoost FX4
Analyst
Just checked on mine - most of them still had roughly a millimeter of give left till they were fully seated. Had a press a little bit to get them seated all the way, but all is well now. Thanks OP for pointing this out
Louis
Lou
NW Pennsylvania
Website
www.enormis.net
21 F150 Crew 3.5 Lariat Sport 502a 6.5bed FX4
Biz Owner
Loose electrical connections heat up over time do to increased resistance at the connection and is never a good thing. Throw in getting jostled while traveling. Intermittent electrical functions are the least of the problem .How many fires have been caused by bad electrical connections.
Good observation. My shop has found F150 fuel pump fuses that end up with a bad contact... yes those trucks are flat bedded in.
I forget the years affected.
mmdpg
Massachusetts
2008 Bullitt Mustang, 2021 F-150 Lariat
Found kick panel fuses all seated, under hood all moved a little when pressed down.
Question: Are people also buying a few emergency replacement fuses? Some I saw in the fuse blocks are much smaller than I've seen in the past. Looking in the manual there are 8 types
Micro 2, Micro 3, Maxi, Mini, M Case, J Case, J Case Low Profile, and Slotted M Case.
They seem to be hard to find, I had to order4 "kits" on Amazon to cover most but not all types.
