You can "fast charge" the HVB -- neutral, foot on gas to rev up ICE and watch your amps go WEEEE. If your HVB is 46 degrees or colder, it limits to 55% SOC or so. Warmer and it can go to 67%. If you're regen braking it will go up to ~72% (my post seeing what e-only could yield. Hard to do as the ICE likes to start https://www.f150gen14.com/forum/threads/manually-rolling-through-gears-in-e-only.16751/ ) Your only usable state of charge is 42% - 72% AT MOST -- the rest of the batt is walled off and ya can't touch it. Below 35% SOC the truck might not work, at all.Can this be explained in a additional way. I appreciate your explanation but I can't quite get my head wrapped around this. For example you circle both dc/dc high voltage and low voltage and placed an = sign. I'm not sure what your trying to explain. I'm sure it's my mind that's not getting it.
Also I'm still not getting a budge of change on the oar reading. I filled a 1/4 tank of 87 octain thinking I would get some reading.
BTW thank you snake for your dashboard. I have to buy a cheep 12 inch tablet. This dashboard is hard to read on a cell phone.
I'm trying to get a handle on the correlation of breaking, idle, down hill charging and raw power during a launch. It's pretty hard to monitor the numbers when stomping on the gas. One min my soc is 63% another min It's 46% I don't understand what conditions are required to get the hvb to max soc. I now see that the truck uses hvb during all normal acceleration until it depleats down to around 48%
So back to back speed/acceleration runs won't be the same until the hvb is recharged. What conditions are required to charge them fastest?
At a stop when the ice decides to run to charge the best amperage input is no more than 8 amps but coasting downhill I've seen as high as 23 amps. Greater with breaks applied.
One last question. When the cluster says 98% recovered after full stop or what ever number is that compared to the amount used to get the truck moving minus the additional fuel used?
It's just the electric energy used in combination?
The DC/DC is making ~15v at 50 amps to power whatever the truck is using. It's doing that by eating the ~286v at 3.4 amps with some losses. In the same way a 20a 120v circuit has as much power as a 10a 240v circuit. Same difference. It's converting HVDC into 15v. That's the primary "alternator" if you will. It uses the starter generator at times, but rarely (to create 12v power). That's what starts the truck 99% of the time -- it'll really rock the truck when it fires off as it just spins it over real fast.
