Blown F-150
So I'm not to sure if you're just using axle bearing as an example or not, but let's talk about the bearings.Ignorance is bliss... Just because your tires can handle your load, doesn't mean the axle bearings can...
So tell me, what's the difference in the bearings on my truck (Max tow, 6.5ft, 5.0 GVWR 7150) with the 9.75 and a 12th Gen Max tow truck with a GVWR of 7700lbs with a 9.75? I'll give you a hint...nothing. Nothing at all, they have the same outside/inside diameter and same width bearings.
If you want to look at it from a different perspective, what's the difference in my bearings and the 14th gen HDPP truck with a GVWR or 7850? Again, nothing as they have the same axle. The differences are more in the spring rates (which I have upgrades in the front and rear of my truck to accommodate) and I'm seeing conflicting info on frame thickness, but I have zero concerns about bending a frame, like none...at all.
One last viewpoint around this for me, would be the towing capacity of my truck. It's rates]d for 11,300lbs of towing. Now to pull that within the parameters outlined by Ford, I wouldn't be able to with how my truck is today and the obvious requirement of a WDH and being within the frontal size limit of the trailer being pulled. My point is that pulling a trailer of that size puts additional strain the bearings, brakes and other components and that is fine according to Ford. The payload ratings are all based on static load numbers, your truck isn't static when you're towing so there has to be margin and design to accommodate for hitting bumps in the road, potholes, G-outs, etc.
I mention tires in my previous post for a specific reason that I should have called out I guess. They add to the weight of the truck, but are un-sprung weight. They don't impact the sprung weight in any meaningful way. One can argue and I would agree that larger/heavier tires do impact braking performance along with handling, however with the tow rating of my truck, I just can't see that being an issue and not something that I've personally noticed causing any concern at all.
Now, here are two pictures...In both my truck is over payload and over the 7150lb's of GVWR the truck is rated for. It is however under both GAWR's. In both scenarios, the truck did roughly 3000mile trips in this config and on varying roads in different conditions. It was fine. If you're talking about grossly overloading, ya that's not for me and a larger truck would be in order.
But ya, I guess ignorance is bliss eh?
