No GPS signal after APIM update
Ffdlt371
Erik
CT
22' F150 Hybrid Platinum
Hey everyone. I just updated my APIM today to 4.2.1. I did it with FDRS and a mongoose. Everything went well and it updated perfectly. NO errors.
After the update, a GWM update appeared and I did that and then a TCU update and I did that. All went smoothly. I am on 4.2.5 now, I believe. Everything seemed to work fine afterwards. However, I noticed that my factory NAV screen now has the GPS with a red circle and a line through it. No GPS signal. Pretty sure it was working before the update. I would have noticed. Any ideas? I already rebooted Sync. No change. Maybe a possible setting default change that turned GPS off??? I have no ideas. Any help would be appreciated! Thanks in advance.
JEB
US
2021 F150 Lariat PB 502a
Module reset—TCU. You can do it with FORScan. Should be an equivalent function in FDRS.
Ffdlt371
Ffdlt371
Erik
CT
I am about to try that. I'll post my result.
ryanc111
Ryan
Bozeman, MT
Had the same issue. Resetting the TCU fixed it for me.
Ffdlt371
Ffdlt371
Erik
CT
No joy. I reset the TCU and the GWM. Still no signal
Do the system reset from the truck menu?
There was a post recently someone had to do that to fix GPS.
From my experience it's no where near 10 days to reconnect everything as it warns. More like an hour last time I used it.
Ffdlt371
Ffdlt371
Erik
CT
Are you referring to a master reset or just the Sync reset?
I did the sync reset but I have not done a master reset. I'm holding off on that cause i really don't want to redo everything. I spoke with sync tech support this morning and all she had me do was reset sync 4 times. Didn't work. Then she told me to go to the dealer.
I'm sure there is a way to fix this ourselves. Just haven't figured it out yet.
Master reset.
The way I look at it if I was in your situation. It doesn't hurt to use the master reset other than a little time to redo my settings. I'm running FDRS now so could run into same problem this weekend.
Ffdlt371
Ffdlt371
Erik
CT
I have the TCU unplugged right now. I may do the rest if it is still not working after I reconnect.
You will lose securalert if you still have it by doing reset. Not sure it will do anything for the GPS issue but that's just what I would try. ?‍♂
JEB
US
If his TCU is up to date, SecuriAlert is dead anyway. Nothing to lose.
JEB
US
Make sure you leave it disconnected for several hours. If that doesn’t work, scan and see if you are showing DTCs in the TCU.
Ffdlt371
Ffdlt371
Erik
CT
That's my plan tonight.
Ffdlt371
Ffdlt371
Erik
CT
Ok. Tried a master reset. Still nothing. I noticed that not only do I not have a GPS signal, I have no Sirius radio signal either. Ford pass works. I did have a DTC in both the apim and the TCU. Both said they lost comms with the other. I reset both modules and the DTCs were gone, but still no signals. I'm calling the dealer. The updates definitely screwed things up.
elaudermilk
2022 F150 PowerBoost Hybrid Lariat
I’m in the exact same situation. And with a borrowed mongoose. So I might be SoL. Updated everything Friday/Saturday. Finished yesterday afternoon and after, neither work.
Both the ford Nav and SiriusXM aren’t connecting, but were working fine before the updates.
