Diode Dynamics
John C.
St. Louis, Missouri
Website
www.diodedynamics.com
2021 Ford F-150
Ford F-150 NEW HitchMount LED Pod | 68% Brighter + 2.5" Adaptor PjBCxYC
Our easiest reverse light upgrade just got 68% brighter. The C1R HitchMount LED Pod features a redesigned circuit board, now delivering over 1,000 lumens of functional light whenever you need it.
Even better? It now fits both 2-inch and 2.5-inch hitches, with a custom-molded adapter sleeve included right in the boxno extra parts needed.
No extra wiring. No permanent mods. Just bright, functional light—now with a DT connector cover for when it's not in use and full coverage under our new Limited Lifetime Warranty.
Ford F-150 NEW HitchMount LED Pod | 68% Brighter + 2.5" Adaptor xwPE2ir
Ford F-150 NEW HitchMount LED Pod | 68% Brighter + 2.5" Adaptor 7C4WMZ4
Ford F-150 NEW HitchMount LED Pod | 68% Brighter + 2.5" Adaptor TLR9JTj
Ford F-150 NEW HitchMount LED Pod | 68% Brighter + 2.5" Adaptor BEtqbVt
Ford F-150 NEW HitchMount LED Pod | 68% Brighter + 2.5" Adaptor 4rB9RrF
Ford F-150 NEW HitchMount LED Pod | 68% Brighter + 2.5" Adaptor aOJEmda
Chalupa
2025 Ford F-150 4X4 RCSB 5.0, 2019 Ford F-350 4X4 SCLB 6.2
If you dive a little deeper it says it is compatible. Their initial search does need updating though.
JohnMcClane
Lower 48
Need beta testers?
Kidding, kind of, still rocking my C1R “Legacy” now, would recommend using some dialectric grease for the connectors everyone, seals were good on mine when I took it out recently, but that grease is cheap.
Wen taillights?
AlexGates
Alex
NW FL
2025 F150 Lariat 5.0
The other brand tested better than the previous model. Still waiting on DD to figure out of it works on the 2025 F150.
crazywayne311
Wayne
Hampton Roads, VA
CTMO
Don’t you have to unplug your 7pin from the truck to use this? So if I need my 7pin to tow I’d need to reconnect it back to the truck?
Diode Dynamics
Diode Dynamics
John C.
St. Louis, Missouri
Website
2021 Ford F-150
@Diode Dynamics
When you go to lookup the correct part on you're website, it has no option for F150 under Ford Models. Better get that fixed
We currently do not have a solution for the 2025 Ford F-150 to be compatible. Sorry about that!
Need beta testers?
Wen taillights?
We don't have plans for tail lights here at Diode Dynamics. However, our sister brand Form Lighting should be bringing something to the market.
Engineering is currently backed up with some major projects, but it's on the list to provide a solution. Our team has kept the alerts and reminders as often as possible to expedite the project.
The 7-pin is unplugged from the back of the bumper, and our harness is plugged in line.
JRonchetto
Jim
Missouri
2021 F-150 XLT 302A
[/QUOTE]
They should make a T connector pigtail so you can plug this in without having to disconnect the wiring to the 7-way trailer harness.
ak49rzrs
Ryan
Alaska
'24 F-150 501A,w/FX4, '18 SHO, '15 F-350 CC/LB 6.7
Liquified fossil recovery
[/QUOTE]
Watch the video, it does exactly that. Their harness plugs in-between so you'll still be able to hook up a trailer plug when needed.
ak49rzrs
Ryan
Alaska
I missed that in the video. Thanks!
I'll admit, looking at their instructions it didn't reflect that being the case. So I then referred to the video. I've been happy with their other products, so will be probably buying one of these for my trucks.
0o7
2024 PB
Can I get confirmation that this will work (with the added brake light feature) on a 2024 XLT Powerboost?
WalterMitty
Chicagoland
2023 F150 Tremor
Ford F-150 NEW HitchMount LED Pod | 68% Brighter + 2.5" Adaptor {filename}
Currently, on your website the options for a 2023 F150 are the following....
a "C1" and a "C1R + Brake"....and is $100 more.
I don't see a stand alone C1R.
Diode Dynamics
Diode Dynamics
John C.
St. Louis, Missouri
Website
2021 Ford F-150
That listing is correct. Sorry for the confusion.
The C1 includes a red running and white reverse.
The C1R includes a red running, high-power brake with optional safety strobe, and a high-power white reverse light.
Ford F-150 NEW HitchMount LED Pod | 68% Brighter + 2.5" Adaptor C1_C1R_Comparison_HitchMount
