konoplya
UPDATE: 6/23 the camera issue was fixed. they had to reconfigure or reprogram the BCM and that did the trick..
I don't know where to turn at this point, but to this board in hopes someone can look at the code and maybe find what's wrong.
Backstory: Last year, my backup camera stopped working. Dealer replaced the camera twice to no luck. Then they replaced some other part, which also didn't fix the issue. They ordered the APIM and that didn't fix the issue either. Truck has been in the shop for the last 2 months almost where they tested wiring, replaced wires, some cables to no avail. Now they're ordering another APIM, but I'm sure that when the second APIM gets here, it won't fix the issue.
Last year, I tweaked a couple settings in FORSCAN pertaining to door locks, but nothing to do with the camera. Then a few days later the camera went out. I used the non-hex editing mode in forscan (the drop down menu one or whatever) for the setting I changed. Perhaps that changed something in the hex code? Its unlikely, but I'm not sure. I'll post all the hex configs of every module below in hopes maybe something did mess up.
The module names are listed at the top of each screenshot.
Any help will be greatly appreciated and I'll even donate to whoever will help me fix the issue.
Thanks a lot for any help.
