Thats not a connector, its a placeholder if you will. You do not need that part if you are following what has been posted.So this is the connector under the glove box, Ive tried to take this apart, anyone have insights on this connector?
Perhaps contact Jesse at Infotainment? I am of the opinion that Jesse can sell you the right components for your upgrade.Yes, sorry should’ve stated that first. My truck is an 22 XL single cab, did the 12” screen and what I think is a Nav apim not sure what the apim came out of. I also did the 12” cluster and ACM.
That’s a Ford app issue there is another thread on this.Has anyone seen this weird message in FordPass after adding the new apim?
Plugged in not charging. It’s not a plug in or electric wtf
these settings pertain to the SDARS enablement and have no bearing on the display size or screen resolution. The only thing you need to look out for is the volume display popup. If your vehicle has the subwoofer like from the B&O sound system, the first digit of the APIM register should be configured to "Log missing DSP Messages" which enables the subwoofer (THX Deep Note). I have the B&O sound system so the first digit of the first hextet in the 7D0-01-01 register is A. (A081-0802-8C cks 90)About to do un-remove SXM from my 2022 using all the fantastic info put together in this thread.
Only question I have is this:
Are the following the correct changes for the 8" or 12" ...or doesn't matter as far as the values. Mine is the 12" and my truck already has a SXM ACM in it from the factory.
APIM
7DO-01-01-2xxx-xxxx-xx
ACM
727-01-01-3xxx-xxxx-xx
Thanks folks.
DLare
Yeap your good!Can anyone confirm this? Thanks in advance!
Yes, your SiriusXM radio ID is G2C19EW4.If what I read is right what I have in my 22 lariat pics attached, I should be able to activate sirius with an as built change and antenna.
read the first post on this thread it’s mentioned thereI have read you need to change 727-01-01 and 7D0-01-01 but I have also read you just need to change 727-01-01 can anyone confirm what needs to be changed. I have 727-01-01 B828 01F1 0002 right now/ 7D0-01-01 0001 0002 8C68. Thank You for any advise you can give. Thanks!
