Multiple exhaust leaks
nitrobass24
Website
redboxplus.com
'21 F150 Platinum PB
Roll offs and Porta-Potties
I remote started the other morning and when I came outside I noticed a bunch of water on the ground by the rear passenger door. I crawled under the truck and it was blowing condensation out of the muffler and resonator in multiple locations.
Would something like this be covered by the PB power train warranty? I’m at 53k miles.
mrtull
Jeffrey
Socorro, NM
2024 XLT PB 302A in Darkened Bronze Metallic, 2023 Ranger Lariat Tremor
Teacher
I believe it's the weep holes that allow moisture to drain from the exhaust so it doesn't pool and rust out the pipes. Mine does it too
Nasto
Neil
Eagle, Idaho
2022 F-150 Lariat SuperCrew
zx6roclet
T
Socal
2023 f150 tremor
Don’t forget to check you headlight fluid while your down there
Murrk847
BFN, USA
2023 5.0 F150 STX
Normal.
During the summer you'll get condensation from your ac by the passenger front tire.
Water out your muffler and also your exhaust tip.
Sometimes I get paranoid and dip my finger in the puddles just to make sure its just water haha
Prevents water blasts out of the tailpipe -- well it helps reduce it significantly. More water is generated than gasoline is burned so it makes sense to deal with it in this manner.
Gros Ventre
Western Wyoming
Water is one of the byproducts of combustion. Until the exhaust system gets fully heated up the metal of the exhaust system will cause that steam to condense inside the system. Those weep holes are there so that as it condenses, it will drain away. If they weren't there the exhaust system could rot away... Why? Well rust is one reason but another is sulfuric acid, which is another byproduct of combustion. So, be happy and let it drain, let it drain let it drain... :)
