Interior Water Leaks
Sdsalc
Sebastian
Elizabethtown KY
2021 ford f150 3.5 eco boost
Hey guys I just bought a 2021 f150 3.5 eco boost 4WD with only 40k miles, and I there’s rain leaking behind the gas and break pedal, driver side floor mat is all soaked and I can’t see where the actual leak is at, has anyone has had this problem??
Kanuck
Winnipeg, Manitoba
Retired Electrician
Is the windshield factory or has it been replaced? if replaced, bad install maybe. Ford did have a recall on the windshield not installed correctly on some trucks.
Porpoise Hork
Bret
IT Sys Admin
Also check the cowl drains on both sides of the truck. They are really a piss-poor design and can get clogged easily. The drain on the passenger side of mine was clogged with debris which flooded the passenger side of my truck through the AC fresh air inlet.
Ford Motor Company
Official Ford Account
Ford
Dearborn
Hi Sebastian! I can look into your F-150's leak concern on my end. To get started, could you please send a private message over with the name/location of your local Ford dealer and your F-150’s VIN?
Sdsalc
Sebastian
Elizabethtown KY
I don’t know if the factory one has been replaced or not but it does leak a lot
