2nd, do not run LT tires at P metric pressures. 37 psi on P metric tires load rating = 45 psi on LT tires. C rated LTs 18s need 48 psi to match E rated 20s at 45 psi or P rated at 37 psiThat is true for similar load capacity tires, but if you switch from P metric or regular metric to LT, it is not always the same pressure to achieve the same load carrying capacity. This calculator is good for making the conversion with all variables accounted for:
https://tiresize.com/pressure-calculator/
