FDHog
You ran 44psi in an SL rated tire and 38 to 40 in an E rated tire? Did you try 48-50 in the E rated General? I just switched to D rated KO2's and run 45-48psi. The truck handles better than with the P rated 20's. It doesn't feel mushy on the road anymore.I just went through this. I went from factory P Hanook's to E General's ATx to SL Nitto's RG. The main reason, to get a lighter weight tire. The instant I drove away from Discount Tire on the Generals, the truck was notably slower to accelerate (3.31 gears), heavier steering/handling and rougher ride. I air up all my tires with 38 to 40 PSI. I tried several air pressures with the Generals, no dice. So back they went and I switched to an SL rated Nitto RG 305/55R20 116Q 2756 lbs. at 44 PSI. Night and day difference over the E tires. Acceleration was back, handling/turning was back, ride was back, love them. I typically tow a #5000 equipment trailer or a #4000 21' boat, and I haven't noticed any difference whatsoever, not even swaying
The way I look at is Ford didn't put E on my truck. I could be wrong but I think I read the non-HDPP rear axle is rated to #5000 ?So why do I want a tire that exceeds the weight carrying capacity of the truck. One reason as mentioned above, sidewall strength. So when you do load up or have a heavy trailer, the truck doesn't sway back and forth as much. I did the sway test with my Generals and then my Nittos but I was hard pressed to see one tire sway more than the other. I suppose if you air up an E rated tire to 80 PSI it would be rock (Flintstone mobile) and not give at all
I also read "no no no, you need an E tire if you do any kind off roading, even a gravel driveway"There is a big write up in 4-Wheeler on the pros and cons of E rated tires for off roading that says otherwise...
Any way, just my $0.02 and hope it helps.
BTW, I ran E rated KO2's on my 2020 Raptor and it rode fine. It's all in finding the right pressure.
