bhom
NJ
21' Platinum PB
So i just ordered my comma 4. From what i am understanding between this thread and the other, is that i should start off with just the latest openpilot until bluepilot gets updated to support it. Is that correct? When installing the harness i assume i should be disconnecting my main and aux battery on my PB. Anything else i should be aware of? Thanks
Ajzride
Ajzride
Automation
No need to disconnect the batteries; it's a simple install. Just watch the videos:
https://bluepilot.dev/2025/08/15/canfd-installation-video-links/
Naveen
Naveen
Louisville, Kentucky
FORD F150 Lightning 2023 XLT 311A
Good morning Guys, Quick question => I do have auto lane change on blinkers. I have noticed when it does the Lane change .. somehow it drags to the right side more (close to the white line) and then centers it back.
Do we have something in settings which can correct this?
Ajzride
Ajzride
Automation
menu --> steering --> lane chagne factor
Spiffy
Usa
2022 platinum powerboost
New issue just started. On interstate im centered and stable. On curves at 70mph it starts to hunt for the center. Eventually starts to ping pong. Grows until its violent and crosses both lines. On version 2.1
Ajzride
Ajzride
Automation
New issue just started. On interstate im centered and stable. On curves at 70mph it starts to hunt for the center. Eventually starts to ping pong. Grows until its violent and crosses both lines. On version 2.2.
The code didn't change. it doesn't magically morph itself. Something had to change physically. Ensure your mount isn't loose. Otherwise, it could be a suspension/steering issue.
Spiffy
Usa
Should I be concerned about maxed out memory?
Ford F-150 Introducing Bluepilot! A Ford specific fork for Comma3X / OpenPilot 17649462115051082541536648825300
Ford F-150 Introducing Bluepilot! A Ford specific fork for Comma3X / OpenPilot 17649462659598274381345184225432
Spiffy
Usa
Yes I understand it doesnt morph and im confident my suspension is ok. Its like the sensitively in just curves are too high. Its over correcting. So far I have done a reboot. I will try a calibration next. My mount is solid. I could try a full wipe and reinstall. Can you please give me the url for 2.1?
Im suspicious about the high memory and storage statistics.
Ajzride
Ajzride
Automation
The system is designed to to use all the memory. If you doubled the memory it would still use it all. Doing a wipe and reinstall will not help. Try the recalibration.
Spiffy
Usa
Ok.
Also I had asked earlier. Will 2.1 work on the new comma? I read from them that they welcome other forks. I assume yes but does it feel the same? I prefer to use 2.1 for the original chill mode and fewer nags. I purposely avoid updates.
I apologize for not recognizing your hard work with the newer versions. Maybe someone can chime in say what there favorite feature is on on the newer versions
Ajzride
Ajzride
Automation
Ok.
No, 2.1 will not run on a C4.
