Ajzride
Ajzride
Automation
Yes. Powerboost Lariat 502a
But I meant to make sure you selected an F150 hybrid and not an escape hybrid, because that would cause issues.
hpwjr
Howard
2023 F150 Powerboost Lariat
Administration
It says on the upper right corner that I’ve selected the 22-23 F150 Hybrid. It said then to recycle the vehicle. I did. And now it does say in the upper right hand corner under vehicle the correct vehicle.
hpwjr
Howard
Administration
Okay. A discovery. I’ve lost my ACC in the truck. With the USB C disconnected from the Open Pilot, my buttons do not activate ACC. All connections seem to snap in solidly.
Ajzride
Ajzride
Automation
Well that sucks. It could be a bad harness, that has happened before. See if everything goes back to normal when you remove the harness.
hpwjr
Howard
Administration
I’m going to unplug the harness and put the truck back to original and see what happens. If all works then I guess I’ve got a bad harness. I’ll recheck connections but all seemed solid.
hpwjr
Howard
Administration
Problem solved. Bad SCCM clock spring. I had previously retrofitted a heated steering wheel and put what was supposed to be a new SCCM with the HSW connection. It was bad. I put my old SCCM back in and everything now works.
The Comma is amazing right out of the box. I’ve just gone around thirty miles of city streets, rural roads and freeways, and it always remained connected. A few over-corrections but still amazing.
Problem is I still do not have Blue Pilot on my settings screen. What have I done wrong?
Ajzride
Ajzride
Automation
what branch are you on? It is called “ford” on some versions and“BluePilot” on others.
hpwjr
Howard
Administration
I uninstalled and reinstalled bit.ly/bp-stable. It seems to be largely functioning, but still only Sunnypilot shows up in the settings menu—no Bluepilot. It did do the calibration over 15 mph this time. Previously I don’t think it did that.
Ajzride
Ajzride
Automation
take a picture of your menu page and post it
be sure to reboot the device after the calibration drive.
hpwjr
Howard
Administration
Here’s the settings menu
Ford F-150 Introducing Bluepilot! A Ford specific fork for Comma3X / OpenPilot image
Ajzride
Ajzride
Automation
go to the first page of the menus and choose reboot device. If the menu still doesn’t show up I’ll have to get your logs to look through.
hpwjr
Howard
Administration
Went down to the bottom of the right hand section a hit reboot. No change.
hpwjr
Howard
Administration
Tell me how to send you my logs and I’ll be happy to send them. But I will say that already this beats Bluecruise.
Ajzride
Ajzride
Automation
DM sent
Ajzride
Ajzride
Automation
I don’t think Stable has a tuning menu
