I have a 2021 F150 power boost FX max tow package. Put on fox 2.0 coil over leveling kit. Only received 1 inch additional height in front. Anyone else had this issue?
I just installed mine as well. Got about the same 1". They're adjusted to "best performance" rather than to "level". You can get 2" out of them max, but you need to adjust them.Is the top collar adjusted to maximum height on the threaded tube?
I would bet most that pay for the max tow are not leveling their trucks.I would imagine there’s more folks out there with the 2021 FX max tow package that are concerned about only getting 1 inch left? It might just be standard for that truck fox 2.0 coilover for best performance. However it’s a little misleading that you’re going to level your truck and still get the best performance when you read all the info from Fox and stage3. However like I mentioned prior I love them and they improve my overall Ride. Doesn’t seem to have as much body roll.
At least with my max tow truck my rear was 2.5 inches higher. Installed a RAS HD kit and it's about 3.5 inches higher now (at 1mm tension setting)I think that guys with max tow are leveling there trucks referncing other ford site lol. I was just confused why it only came up an inch and not 2” when bolted directly in.
