How much does 3" inch lift with 35's affect PowerBoost's performance and MPG?
Powerboost is heavy truck -- with you in it it's easy over 6klbs. That's extra mass to offset trailer weight. Strongest frame of all F150s sans raptor. GVWR is under-rated for what it's got. A lot of F150 trims are around the 5klb mark. All of the additional weight is inside of the frame rails so it's got a good CG for what it is.
P.F.T. Guy
Ben
Mountain Home, Idaho
Toyota Tacoma TRD, Toyota Highlander, Ford Bronco
fgutz3rd
fgutz3rd
Fernando
2021 Ford F 150 Lariat
Retired Army
Thanks. Looks like it took a hit as far as mpg. I just got it so I’m gonna give it a month to figure out exact numbers. Thanks for the help
z-man
Las Vegas, NV
2022 F150 Lariat Powerboost
Are they E rated tires? You have factory wheels so no weight gain there but if they are E rated tires you have a much heavier tire than stock. Looks great BTW.
fgutz3rd
fgutz3rd
Fernando
Retired Army
First thanks. I think the 3 inch lift is a good lift. Still able to utilize the truck bed. As for the tire, where do I check the rating
z-man
Las Vegas, NV
On the side wall. For the weight you would need to look it up online.
travisN000
Travis
Oregon
2021 F150 Powerboost CCSB
I recently put a 6112/5160 kit in my shortbed powerboost.
I had the dealer set the struts to max height (2.5 in lift) and still have about 1.5 inches of rake, so probably only got close to 2 in of actual lift d/t the extra weight of the PB. Also added 285/65r20 Maxxis ATs (34.7x11.6 in) on stock sport wheels.
For the first few months of ownership I got 17-20mpg; this gradually improved to 18-28 as I learned to manage the throttle and maximise the electric motor in the months following.
Since installing tires and the level, my MPG is back down to 17-22... some of that is probably because the new tires and suspension make me want to drive it harder ;)
fgutz3rd
fgutz3rd
Fernando
Retired Army
Looks good. Yeah I just have to drive it. I’m sure it will gradually go up some. Thanks
fgutz3rd
fgutz3rd
Fernando
Retired Army
Ford F-150 How much does 3" inch lift with 35's affect PowerBoost's performance and MPG? F8BC65A8-29F8-4EF9-B08A-49E62D9CD382
this is all the info on the tire. Also I downloaded a speed test app and it shows I have a 5
Mph difference. Any ideas on how to correct it
z-man
Las Vegas, NV
FORSCAN
What type of tires are they and what is next to what looks like 128?
fgutz3rd
fgutz3rd
Fernando
Retired Army
vertelli terrono m/t
Ford F-150 How much does 3" inch lift with 35's affect PowerBoost's performance and MPG? image
travisN000
Travis
Oregon
Manufacturer specs:
SizeLI/SRTread DepthOverall DiameterSection WidthPLYMax Load Capacity @PSIStock#
35X12.50R18LT128Q19.7834.5212.50123970@80VC2478
Custom Offsets has a bit more data (includes weight; but different tread depth):
Brand: Vercelli
Model: Terreno M/T
Inventory Number: AOTVC2478
Aspect Ratio: 12.5
Inflated Diameter: 34.52
Inflated Width: 12.5
Load Index: 128
Load Range: F
Max Load Pressure: 3970@80
Ply: 12
Section Width: 35
Service Description: 128Q
Sidewall: BSW
Speed Index: Q
Tire Rim Diameter: 18
Tire Type: Mud Terrain
Tire Type2: Performance
Tread Depth: 15.7
Weight: 68.43 lbs
