How ford picks what trucks are being built
Blackout150
Stephen
Elk Grove ca
2013 F150 2022 F150
This is a very interesting read for those that want to know the process. It’s super long but explained very well
How Ford builds are selected each week
I found this on the truck forum
I see this question a lot. So, I'll try to answer it (subject to corrections).
It is largely determined by (1) dealer allocation, (2) order priority, and (3) component availability and (4) production capacity (part shortages not withstanding).
Placing Your Order at the Dealership:
Two (major) things affect your order once your dealer enters it into the system: priority order code and dealer allocation.
Priority Code:
Ford only schedules so many orders (from dealers) each week. As a result, each dealership has to determine what order (sequence) their truck orders should be picked up in. A holding queue for that dealership, if you will, with all the truck orders in a single line from which only one truck at a time can be released, is needed. Think of it as thread off of a spool or a print job from a printer queue.
To do this, the dealer uses/assigns a priority code from 10 to 99 to each order. If your dealer prints your order or shows you the screen, you'll see it on there.
While 10 is a lower numerical number, it is the highest priority order code a dealer can assign. Subsequently, while 99 is a higher numerical value, it is the lowest priority. Think of a priority order code the same way you would think of a college football player being "ranked" for an upcoming draft (1st is highest ranked, then 2nd, then 3rd, etc.). Until the orders are selected for scheduling by Ford, the priority order codes only apply internally at each dealership. Meaning, this is the order in which that the dealership will "release" the customer orders in when Ford asks for them. This allows the dealership to prioritize certain trucks AHEAD of other trucks, regardless of when the customer actually placed the order. That's why it pays to get the highest priority order code (lowest number) assigned to your order. Dealerships often (but not always) assign lower priority order codes (higher numbers) to stock orders while assigning higher priority order codes (lower numbers) to retail orders so you (a retail buyer placing an order) get your truck faster, which means they sell a truck faster.
Before moving on, note that while the highest priority order code a DEALERSHIP can assign is 10, Ford Motor Company (the manufacturer) can assign a priority order code of 01 to 09. Essentially, Ford can decide if any particular dealer orders should be prioritized higher than "most" others. They often use higher priority to replace vehicles damaged during transport.
So at this point, we have a list of truck orders for each dealer and the orders are lined up in the sequence that the dealer wants them pulled for scheduling based on their priority order code. I believe tiebreakers (same priority order code for more than one truck) are determined by the date/time the order was entered).
Allocation:
Ford allows each dealer to order a certain number of F150's per week. This is called dealer allocation. The number of trucks a dealership is allocated differs from dealer to dealer. One dealer may have an allocation of 10 trucks per week, while another might have 50 per week. Ford determines allocation for each dealer, largely depending on how many trucks that dealership is moving.
Keep allocation in mind for later.
How Orders are Picked From Order System (from the dealers) FOR Scheduling:
On WED/THU of each week, the Ford planning system reviews all the orders at the dealerships to select which ones it is going to accept into the system for purposes of scheduling them to be built. It does NOT just take ALL orders and schedule them for build.
Which sequence the orders are selected to come into the planning system is based on a combination of (a) round-robin dealership selection process (think of it as teams participating in the NFL draft) and (b) allocation (how many TOTAL orders (aka players) a single dealer can select during the entire draft (for the entire week).
Here's the process, at very high level:
Think of the selection process working like the "draft" process for major sports: Each team (dealer) gets ONE choice per "round" to send ONE order for planning, just like each team gets to select ONE college player per round.
Round 1: Each dealership gets ONE choice. For each dealership, the truck with the highest priority order code (lowest number) within that dealership is selected. Once every dealer has had the opportunity to send ONE order for planning, its starts back over. Same order of teams, just a new round.
Round 2: Each dealer, again, gets ONE choice. They send the truck order that had the next highest priority order code (lowest number) in their queue.
Round 3, 4, 5 ... : It goes from round to round allowing each dealer to get ONE pick per round, and each dealer picking their highest priority customer order left in the queue.
Now here's the tricky part: Remember dealer allocation?
Dealers don't just get to keep submitting orders until every order they have has been sent for scheduling. This is largely due to capacity and material planning.
Each week, each dealer will only have orders picked for scheduling until the dealer's number of orders selected reaches their allocation. For example, if a dealership's allocation is 10 trucks per week, that dealership will "cut off" from having more orders selected for scheduling starting in "Round 11". That dealership is done participating in the draft for that week.
After allocation is met and a dealer is cut off for the week, the orders left over in that dealership's internal queue must now wait until NEXT week for the same process to begin.
The very next WED/THU, the same process starts again: Round-robin, highest priority, next highest priority, etc., until allocation is met for that week, then no more for that dealership again until the following week.
This is why it, if you're trying to order a vehicle that is in high demand, you should work with a dealer that has a very large allocation. They can order more trucks per week. It' less likely that your order will get held over until the following week (or weeks).
Allocation is why some people on here have been waiting for several MONTHS just to see their truck get scheduled to be built, while other guys ordered much LATER, yet their trucks are already scheduled, built, or delivered.
How Picked Orders are Scheduled for Build AFTER Ford Selects Them Each Week:
Remember when I said that priority order code only applies internally? Well, that now changes. Now, the priority order code is a factor in determining which orders get scheduled before other orders across all dealership orders.
Let's say that 15,000 orders for F150 trucks are selected to be scheduled for build. The order with the highest priority (lowest number) gets scheduled first. Lots of trucks have the same priority code, so the process generally follows a pattern of date/time the order was entered (selected during the "draft", which was based on the date/time the orders were entered). It's actually more involved then that, but that's it in a nutshell.
Vehicles are first assigned to be built during a certain week (shows as a Monday date). As it gets closer to that week, the vehicles are assigned to specific build DATES (the day of). All of this is based on (and sometimes is affected later by) a variable plethora of variables, including material planning/component and part availability, plant production capacity and rates, the labor issues or weather causing delays or shortages, etc., etc..
Understand that trucks are not built in the order of the VIN number. A VIN is assigned before a truck is built. There are many factors that affect when a truck will be assigned to be built, but suffice it to say, they aren't in VIN order.
As a consequence, the assembly plant needs a way to keep track of what order they WILL build the trucks in. If they didn't, they would not be able to ensure that the RIGHT parts are at the RIGHT places at the RIGHT times. Today, many components are shipped to the assembly plants either sequences (a specific component is going to be installed on one EXACT VIN) or they are shipped "just in time". The latter simply allows Ford to maintain a much smaller component inventory level. If you go back 15-20 years or more, they used to keep much more inventory on hand -- sometimes WEEKS. Carrying inventory costs money, and JIT reduces this cost.
How they keep track of the build order is by what is called a BLEND number. Actually, it's a combination of a BLEND number and a ROTATION number, but that's not important.
A blend number is nothing more than bank of numbers assigned in numerical order to a vehicle when it's scheduled. For the F150, it's ~10K numbers from 0001 to 9999 The trucks are built in order of blend number. 3456 is after 3455 and before 3457. Occasionally, an odd blend number will come along. If a vehicle build is put on hold at the last minute, simply re-insert it (same blend number) somewhere later.
Hope this helps someone understand the order and scheduling process.
{tpc}
Anthony
Berkley, MI
Quite interesting. I dug up my old paperwork. My priority number was 19 and I ordered on 10/18/21, received the truck on 12/28/21.
Blackout150
Blackout150
Stephen
Elk Grove ca
2013 F150 2022 F150
Wow. Maybe I should have ordered then. Pretty fast turnaround
C_Harris
Summerville, SC
'22 SQ King Ranch
Health Care
Priority Code:
Allocation:
I ordered on 1/27 from Granger (very high volume), have been a Priority 02 for month and a half, and am unscheduled clean. So how does that figure into the delays/non-selection? Ford has said there are no contstraints for my build since it is clean. ??‍♂
Blackout150
Blackout150
Stephen
Elk Grove ca
2013 F150 2022 F150
That’s a really good question
Gutshot
Matt
2022 XLT screw
Aggregate junkie
My order was placed on 10/9/21, priority 12, arrived at dealer 12/16/21, I waited a week to get another $500 incentive then took delivery last week of the year.
Wolf Man
Brad
Silver State
2021 F150 Lariat
My priority code 10 was changed to 02 by Ford regional and it still took about 7 mos for it to be built after the pc change and was never on chip hold. It could have been on paint hold, a few times I had seen the commodity list they were out of SQ
thudnblunder
Bay Area, CA
2022 F150 PowerBoost
Cloud Software Architect
How do you check the commodity list?
Wolf Man
Brad
Silver State
2021 F150 Lariat
It used to be posted on here occasionally by other members and commodity list probably isn't the correct term. I've actually forgot what it was called but it is a list that shows what constraints there are. For instance among other things it would show what options aren't being built such as an order with the SQ (Smoked Quartz) paint, maybe a certain engine wasn't available, perhaps Max Recline seats, the Snow Plow option, etc. I think this was a list updated weekly or bi-weekly. All dealers get this list.
thudnblunder
Bay Area, CA
Thanks!
Kodiak
Thanks for posting this!
GIjoe
Joe
2013 f250
Granger is high volume but only gets so much allocation, that’s probably why you’re waiting
Rockman5159
Rocky
Marion SC
2021 ford f150 FX4
Priority Code:
Allocation:
WOW. Very interestin information. I looked back on my order information and found my priorty code was 80. That expalins why I ordered in August and didnt get my truck until December. Thanks for the explantaion. I think everyone on this forum will benefit from you post. Thanks again
Blackout150
Blackout150
Stephen
Elk Grove ca
2013 F150 2022 F150
That list would be really good to see so people could understand what is taking their orders longer then normal.
