Heated steering wheel not very hot?
Dybalr
Ryan
Buzzards Bay, MA
2021 F-150 platinum
Forscan will let you adjust the temperature as well as the duration. I just did this on mine. It works.
Knickell
Mazda Protege, Ford F-150
Can you give a few more details as to this?
How many degrees can you adjust it? Would it work for the ventilated seats as well?
Dybalr
Ryan
Buzzards Bay, MA
2021 F-150 platinum
I have it all written down at home, but I believe it starts at 35 degrees Celsius and let’s you go up to 39 degrees.
the default duration is at like 10 minutes but can be set to indefinite.
I settled on 37 degrees and 20 minutes.
Doesn’t appear there is access to the seats though.
when I get home I’ll get the specifics regarding module and settings
Knickell
Very nice! Thank you for the info!!
Louis
Lou
NW Pennsylvania
Website
www.enormis.net
21 F150 Crew 3.5 Lariat Sport 502a 6.5bed FX4
Biz Owner
Here is what I found on the Forscan. Lots of options for heated steering wheel temp and time. SCCM module
Ford F-150 Heated steering wheel not very hot? Heated SW settings 20210422_190433
Mrtosh
Mrtosh
Sean
WI
21 f150 powerboost
I've always been curious, does Forscan void warranty? I would love to fix this issue once and for all.
Louis
Lou
NW Pennsylvania
Website
www.enormis.net
Biz Owner
Forscan does not AUTOMATICALLY void your warranty. Magnuson Moss Act was enacted into Federal law in 1975 and States, nothing will automatically VOID your warranty UNLESS someone can show or prove that something CAUSED or CONTRIBUTED to a Failure in the vehicle.
Mrtosh
Mrtosh
Sean
WI
21 f150 powerboost
Does this fall into the category of tuning a vehicle?
dolsen
KY
2022 Rapid Red 701A
No, tuning a vehicle changes the operating parameters set by FOMOCO and rewrites the programming, whereas changing as built is essentially the same as "flipping a switch" from one set of programming to another. A program that was created by Ford engineers.
This is NOT to say that any issues arising after changing as-builts will or will not be covered by warranty. At the end of the day, Ford can come up with any reason they want to deny a warranty claim. But the burden of proof is on them.
However, as long as you don't try to get "creative" with the as-built changes, I cannot see any issues popping up that you cannot easily reverse by setting your as-built value back to stock.
thunderf150
Max
Ontario, Canada
2023 F150 Lariat 501a
HR
I so needed this! Thank You.
23 Lariat here and the same issue not too hot. I hope there was something for the seats as well.
DBL R
Jarred
Washington
2021 F150 powerboost
PA
I suspect there is a safety feature from overheat. Initially turning it on my steering wheel gets almost too hot for 10-15 minutes then starts reducing in heat. If you turn it off and on again it goes back to kick wang mode.
superfordman
Troy
NE CO
2024 Raptor 801A
Precision Ag Guru
Yep there is for each of the three levels, case in point, I noticed they were different between my 21 and 23 in the Forscan values. My 21 you couldn't even use medium or high levels as it would burn your ass off pretty much, the levels of my 23 are toned down a bit.
Yes, it does exactly that, has a heat-cool cycle it goes through, many others have noticed it as well but really no way to circumvent it as that is just how it works.
thunderf150
Max
Ontario, Canada
HR
So were you able to find it for the 23 as well ? My eyes go glittery when you reply to an issue thinking that we kinda have the same spec truck and you would just have all the answers ?
superfordman
Troy
NE CO
2024 Raptor 801A
Precision Ag Guru
Play around with these, but there are similar values in the DSM as well that might also need adjusted to match.
Ford F-150 Heated steering wheel not very hot? 1698458986609
2Lazy2P
PNW
Il Dolce Far Niente
The heated steering wheel is too hot to my touch. I have to turn it off after a few minutes.
