foofoodar
- First Name
- Aaron
- Joined
- Dec 28, 2023
- Threads
- 3
- Messages
- 24
- Reaction score
- 15
- Location
- Fort Myers FL
- Vehicles
- 2021 F150 Lariat Powerboost
I have a 2021 powerboost, had the dealer flush the transmission fluid with around 70,000 miles, they said they don't do drain and fills, and the filter isn't meant to be changed unless the trans needs a rebuild.
Now I have about 72,000 miles on the truck, and from 1-3 it can be anywhere from a normal shift to a slight bump, to a harsh jerk, 3-4 sometimes has a loss of power before engaging. Putting the truck in tow mode the 1-2 shift also results in a huge delay and harsh shift. Some of the higher gears when downshifting are also a bit harsh.
I of course went back to the dealer, left the truck with them for 2 days for them to only tell me they didn't notice anything on the test drive, so I went in and did a test drive with the manager, and magically it didn't act near as bad as it normally does, and the manager had all kinds of excuses of that's normal, the trans isn't warmed up yet, etc, and the moment I drive away and go home I get some harsh shifts...
I am kind of wondering if I need to have a drain and fill performed with a filter change, not sure if the filter could be clogged? I used FDRS, updated to the latest PCM update, cleared the tables, and while it seems a little better, it still has issues, so I figured I'd post here to see what everybody else thinks?
