Gros Ventre
- First Name
- Bill
- Joined
- Nov 13, 2021
- Threads
- 47
- Messages
- 2,690
- Reaction score
- 1,815
- Location
- Western Wyoming
- Vehicles
- Powerboost
My purpose wasn't to give a Post-doctoral dissertation... rather to simply at a top level for those reading it to get the general idea. Thank you for your guarantee abut BDC... For those who've never operated or repaired a Fairbanks-Morse opposed piston, valve-less, two stroke diesel engine going through that level of stuff was just over the top... So write down that stuff you wrote above and submit it for your next academic degree submission... but can it for these kind of discussions. PS There's nothing pseudo about the compression ratio, it is what it is... or are you trying to explain the atkinson cycle engine? Hm-m-m...You’re considering only static compression ratios and not dynamic compression ratios. The only way you would not change dynamic compression ratio is if the valves closed at BDC (assuming the cylinder reaches ambient air pressure at BDC) for both 87 and 93 octane. I don’t know the cam profiles of these trucks so I don’t know exactly where the valves close in relation to the piston position, but I can pretty much guarantee it isn’t at BDC. Using higher octane allows “advanced timing”. This means that the valves will close closer to (but still after) BDC when using higher octane fuels than when using lower octane fuels (aka retarded timing). Advancing the timing and closing the intake valves sooner means less air is pushed out of the cylinder giving a higher *effective* AKA dynamic compression ratio. It sounds complex, but really the theory is pretty simple
Variable timing is kind of a “pseudo” variable compression ratio
