None of it is free or cheap either. ?
I'm not filling up my 36 gallon tank for $100. ?There’s at least 8 mods on my list that are under $100 and another 2 mods that start at $100. It takes about $100 to fill your truck up with gas. If that ain’t cheap, then I don’t know if you should be driving a truck my guy. ???
buy them if you want but you cant install them on the gen 4 5.0. Different design…aka…doesnt use oil pump gears.You definitely can’t skip over these weak OEM 5.0L Coyote Oil Pump Gears if you plan on adding boost to your truck via Superchargers or Turbo’s because under high boost/RPM’s they break. They are easily the weakest part of the Coyote engine besides that oil pump belt. You have to open up the oil pump and go with billet gears inside.
https://www.f150forum.com/f129/coyote-v8-belt-driven-oil-pump-496161/#post6873536
