Flat pad between cabin and bed
Rah150
Ryan
23 F150 Lariat Powerboost
I struggled to find any posts here on this topic.
I have a 23 PB and the felt pad between the cabin and bed looks to be slowly falling off.
I think it may be to reduce sound in cabin?
When my AC is running I can feel a lot of cold air coming from the gap where it’s falling down so maybe also for insulation?
Have others had this issue? Should I just ignore it or what do yall recommend?
Davidwnuc
Mississippi
On order ‘22 RCSB.
Part of mine is coming off too.
There are vents on the back of the cab to let air out when you shut the doors and when running the HVAC on fresh air mode. All cars have these vents. That is why you feel cool air coming out.
if you use recirc, you wont loose as much air out the vents. But totally normal to feel the air.
I cant help with the pad things…sound insulation is my bet.
Ford Motor Company
Official Ford Account
Ford
Dearborn
Hi Ryan, If you’d like further assistance regarding the insulation feel free to send us a private message with your VIN and local Ford dealer. Thank you!
Big Dog Daddy
New Jersey
There are 2 plastic louvered vents on the back of the cab, these vents allow air to exit as fresh air is taken in. This is why you're feeling the cold air coming from between the cab and the box of the truck. The picture is of a Super Duty, but the F-150 is similar.
Ford F-150 Flat pad between cabin and bed Captur
Porpoise Hork
Bret
IT Sys Admin
It's the sound insulator pads. Mine was just replaced under warranty as it was separating form the cab as well as installed incorrectly and causing water to seep past the cab vents. The dealer had to unbolt the bed to replace the pads and vents.
There are two of them back there. ML3Z*1540380A and ML3Z*1540381A
digitaltrucker
Ed
2021 F150 Platinum, 2013 F150 Lariat, 2008 F150 Lariat, 2005 XLT, 89 F150 Lariat
Can you advise your fix? I just discovered my 21 Platinum has this issue also.
