Kelvin
I did some update to my 2021 Lariat 3.5EB transmission at the weekend ( it is 55K kilometers now), and it seems make it much smoother when changing gears, almost like new.
My F150 used to be silky smooth when it was new purchased, after about 20K kilometers, it started showing clunky when changing gear between 5, 4, 3.
So I did drain and refill only when it hit 30K kilometers, but clunky symptoms seems no change and even worse as time went by. It got to the point when light brake to stop (like city drive with red light), from 5 down to 3, it would suddenly has a big bump, like it got rear ended, which is really uncomfortable.
Well, I searched up and down the forum, and I used Forscan to clean adaptive table and stop using adaptive learning, this seems fixed the problem when gear up shift, I don't feel any clunky up shift anymore. However, the down shift clunky still persist, and the random "rear end" bump still there.
Then I adapted my own driving habit, when doing brake, I always step on brake multiple times instead of steady step on brake paddle, especially when it shift down from 5 to 4, release the brake and brake again, this can avoid the down **** clunky, and avoid the `rear end` bump.
Still not happy with it, downshift was still rough, and besides, and I had to be aware the way how I brake.
After countless google search, I decided to do something about it.
Found Sonnax has some parts/kits for valve body for dealing with clunky shift. Bought some parts from Sonnax for valve body piston update, and I did the update fixes.
It took me nine hours to finish, mainly because I had to craw in and craw out too many times on drive way under the truck, and I don't have good fluid extractor or sucking gun, but I did it.
After few driving around, it seems fixed the clunky issue, I don't need to worry about how I brake now, just brake like driving any other car and I don't feel the hard down shift no "rear end" bump,
but time will tell if it is because of the parts fixes or because of the transmission oil change.
So for anyone who are having the clunky issue, maybe you can give it a try too.
The parts from Sonnax,
I only bought these two parts: Main pressure regulator valve kit, and Solenoid stabilization clip insert.
For the main pressure regulator value kit, the spring comes with it is thin and weak compare to what it has in stock valve body, and when I observed the boar, it seems no scratch or damage, then I decided to stay with stock piston and spring but only replace the end plug with Sonnax's end plug with o ring.
For the solenoid clip inserts, before install it, you can definitely rock the solenoids and feel some wiggle play, after put in the clip inserts, none of the 6 solenoid has any play room.
Here are two youtube I watched before I did my job:
How remove valve body:
How to split upper and lower valve body:
Overall, the job seems easy enough for me to do it on my drive way.
The valve body is pretty serviceable, but pay attention to these and do it carefully otherwise, it will cause damage and can not recover:
#1 The bolts of valve body: they use E torx 12 socket, and it is very easy to strip it, so pay attention and must use good socket, otherwise you will be screwed, because it need to torque to 106 inch/pound.
#2 The sensor on the bottom: This sensor is mentioned in the second Youtube video that you need to disconnect before split valve body. The sensor is using plastic stuff for its position, since the valve body is a bit heavy, be very careful when you handle the valve body, not to touch that sensor with force, otherwise, the little plastic tab may break and it can never position itself in right direction. So pay attention and careful look at it, you will understand what I am talking about.
When installing valve body back to transmission case, the valve body is kind of heavy and my arms were giving up. So I used a jack to help support my arms, and it was much easier for my arm muscle.
And as for mercon ULV fluid, I prepared 14 bottle (14 quarts) instead of only 6-7 bottles. which I am glad I had that many bottles. Because dropping the filter would lose 6 to 7 quarts of fluid, but after dropping of the valve body, it will drain more fluid, and almost drain all of it, I ended up refill back about 11 bottles of ULV fluid.
For the torque spec, the dealer where I bought transmission oil could not find it or they just don't want to find it for me, so I did print an image from one of the youtub (I can not find that youtube anymore), and here it goes
Again, this is my own experience, just sharing what I did and what I had.
Anyone do this on your own risk, I am not responsible for any consequence or damage for your own doing.
