i was wondering if it is down , maybe at the limit or real close and the wind pressure is causing the top lip to pop out and fwd as the lower parts schooches aft .I youtubed a couple of videos that were more about the removal of the active airdam and although I don't see how the actuators on each end could possibly be raised, it did appear that there's some slop, and perhaps even a little elongation in the holes where the dam itself fastens to the two actuators.
But the videos weren't conclusive enough to be honest.
However, once you see the 3 screw holes on each end of the dam you can see that it's likely possible to elongate the holes even more if it's necessary to get it up a little higher?
For those that have had it catch on the front lip, is it just barely coming down too low? Or is it a considerable amount?
I'm wondering just how beneficial this aitr dam is anyway as fas a mpgs. I like the look of the the Raptor front skid plate. It looks som much cleaner and the looks of more ground clearanceI youtubed a couple of videos that were more about the removal of the active airdam and although I don't see how the actuators on each end could possibly be raised, it did appear that there's some slop, and perhaps even a little elongation in the holes where the dam itself fastens to the two actuators.
I'm sure that fully depends on how much time (mileage) your truck spends at long sustained driving above 55mph?I'm wondering just how beneficial this aitr dam is anyway as fas a mpgs. I like the look of the the Raptor front skid plate. It looks som much cleaner and the looks of more ground clearance
