Factory Dual Exhaust - Can You Adjust the Tips?
FaaWrenchBndr
Denver, IN
‘24 XLT Powerboost
A good exhaust shop can get these to the exact location you want
DNazzy’s2025
DNazzy’s2025
Georgia
2025 Ford F150 Lariat
Project Manager
Not much adjustment at all. I just put a direct fit flowmaster muffler on my BAP Lariat 5.0L and the tips moved further in like yours are. I don't like it. But after spending hours under the vehicle making adjustments, it is only marginally better.
There are two ways to try. Loosen the clamps where the tailpipes meet the muffler and try sliding them out a bit. Not much to gain there at all...maybe 1/2". Or loosen the clamp between the resonator and muffler and try sliding that out a bit. Not much to gain here either. If you try anything, soak the exhaust hangers in WD-40 so they slide in the rubber mounts.
Thank you, I’ll see if I can get any wiggle out of it. Sounds very limited adjustment
DNazzy’s2025
DNazzy’s2025
Georgia
Project Manager
This drove me nuts after I installed a Borla midpipe. The tips had zero in/out adjustment for me. I ended up loosening the pipes above the rear axle and using a dead blow hammer to move the passenger side further back about a half inch. I really hate being OCD.
I do too. It keeps me up at night lol
DNazzy’s2025
DNazzy’s2025
Georgia
Project Manager
Yep…. Which I don’t want to do. But, probably my best bet to get them where I want them
FaaWrenchBndr
Denver, IN
‘24 XLT Powerboost
I understand, years ago had a Dodge that had tips that were a bit too recessed that could be adjusted out anymore. That’s what I ended up doing to get it to look how I wanted it.
If you do figure out a way to get these, tweak to your liking, please do share it for the masses
DNazzy’s2025
DNazzy’s2025
Georgia
Project Manager
I’ll definitely let you guys know if I am able to get any adjustment out of it. Thanks everyone for their input too!
gagliano7
Joe
Monroe NY
I was able to adjust mine when I installed the Flowfx muffler. It is a pain but can be done.
Dakar09
Tony
Dedham, MA
2024 F-150 Lariat 5.0L
So...got it much closer to even. My issue was the passenger side pipe. I freed up the rear-most hanger (by the tip) then loosened the clamp on where it meets the muffler pipes.
Then I noticed it was the tailpipe hanger up near the spare tire preventing the adjustment. Took that off completely, twisted the pipe to get it more aligned (but left it loose) then did final adjustment with the tailpipe hanger to line it up and tightened that down. Then tightened the pipe clamp. Last was that middle hanger. Had to shim it out with a nut and left off the upper bolt altogether.
Dakar09
Tony
Dedham, MA
This hanger, btw...
The nut is between the bottom of the frame and that bolt. The bolt on the upright part would no longer go in because it sits a 1/2" lower now. It doesn't move, so I'm not worried. I think this hanger is overkill, tbh
Ford F-150 Factory Dual Exhaust - Can You Adjust the Tips? Passenger hanger
DNazzy’s2025
DNazzy’s2025
Georgia
Project Manager
So I finally had some free time and decided to look at the mid-pipe connection as it’s really the only logical place to adjust how far the tips stick out. Got my Dremel out with metal cutting disk, buzzed off the little stop piece that keeps it locked in place. Once I got that piece removed, I took my 5lb sledge and hit the muffler can and it easily slid the whole system back towards the bumper. I hit it back a little over a 1/4”. I’m sure there’s enough exhaust pipe in that connection to go back a little further. I might hit it out a bit further. But it looks a lot better. There is hope for those that are OCD like me.
Ford F-150 Factory Dual Exhaust - Can You Adjust the Tips? IMG_3494
Ford F-150 Factory Dual Exhaust - Can You Adjust the Tips? IMG_3491
Ford F-150 Factory Dual Exhaust - Can You Adjust the Tips? IMG_3493
Ford F-150 Factory Dual Exhaust - Can You Adjust the Tips? IMG_3492
