BAP - Dual Exhaust - Motor Specific?
Kodiak
I have seen pictures of the BAP and some show a dual exhaust and others just have the regular exhaust. Is that dual exhaust - model specific or motor specific or a combo of both?
KBKEITH
As part of the BAP, the dual pipes requires the regular, non-PowerBoost, 3.5. All other engines get the single pipe.
Kodiak
Kodiak
Thanks for the reply. I'm getting the PB Lariat 4x4 so single pipe for me.
I would have thought the 5.0 would have gotten it but I knew it had to be a narrow offering.
tony72cutlass's'
Tony
Halifax
FWIW the 5.0 sounds great with the single IMO
My cutlass also has the original single exhaust and sounds like a hippo farting in a bathtub, if you're into that kinda sound
KBKEITH
They are probably just using the same exhaust setup as the Tremor which has the standard 3.5 hence the single pipe on all other engine options.
12Lariat21
Jonathan
2021 Lariat 502A
Engineering Manager
It's either 2.7 or 3.5 EB engine, it also is only available with the 145" WB. 5.5' box with SCREW. Anything else you get the standard single pipe...with a chrome tip, if that makes any sense..
KBKEITH
Unless I am misunderstanding your post, the dual exhaust is only available with the 3.5. The 2.7 only gets you a single pipe.
12Lariat21
Jonathan
2021 Lariat 502A
Engineering Manager
No, I was just wrong. I misinterpreted the order guide. The only dual exhaust for BAP is the 3.5L EB
bigjohnp
Jean
Quebec
2018 Ford F150 XLT Sport
You're missing the sound effects....
Kodiak
Kodiak
Smelly Hippo.
What are they feeding you.
