powerboatr
North East Texas, Piney Woods
2024 F250 King Ranch Chrome
Retired Navy Senior Chief
Ryan74
California
2023 XLT Carbonized Gray 4x4
Im not a truck guy, what do these do exactly?
powerboatr
powerboatr
i was wondering same thing? do tremor trucks get stronger half shafts? i have no idea
the description lists specific items.
  • Features Raptor outboard CV joint
  • Upgraded modified CV boot
Vin
hotrodmex
Ca
22 Lariat 500.5a
I'd bet a beer they (the outboard CV joints) are larger in diameter to house larger bearings for the harsher intended use.
zimmer0
DFW, TX
also to withstand the front locker IMO. Doubt it will provide much benefit as a replacement for standard 4wd trucks.
Bugzuki
Paul
Reno, NV
2021 Ford F150 PowerBoost Super Crew 4x4
Can you get the front Torsen limited slip differential?
hotrodmex
Ca
22 Lariat 500.5a
Yes. It's a Ford Motorsport part that is also available form the manufacturer as a retail part.
https://performanceparts.ford.com/part/M-4204-F150LS
https://www.steeda.com/ford-perform...W2FdqetzEs7Agvc6eldsENvgN3Du_VLUEJMNMD2kutv0U
EDIT: Might have sounded like I was saying Steeda was the manufacturer, but they are just another source for the part, of MANY.
even if you could it would be expensive as f*ck to install.
For a diff install? Depending on the shops in your location it could be as cheap as $500. With a dial gauge and some patience you could do it in your driveway.
JohnMcClane
Lower 48
Thank you for this, really, I don't know that I'll ever do it, but folks, it can be done, and it can be done reasonably.
It's definitely in my backlog now.
thechester
MN
2022 F150
Why only 2021 models and not 2022s? Also, how does one know if they have the correct front axles to accept the torsen?
