Error Message: Wireless Connection Failed
Kanuck
Winnipeg, Manitoba
Retired Electrician
@Kanuck Since you have access to FDRS, did you update all the modules listed in
TSB 25-2048 ?
I can only update what FDRS is showing at that time. I would have to look in my files to see what ones were updated. I do know my Sync is at 24127 tho.
hammer58
hammer58
2022 F150 STX
TSB 25-2048 ?
I purchased the 2 day software access and updated all modules except the ABS, BCM and ACM.
I didn't update the ABS because I am not having issues with it.
I didn't update the BCM because I got a message that I didn't have proper security access.
I tried to update the ACM several times and PTS still shows that there is an update available for it.
There also was not a APIM update available.
This is what I see in the PTS website
Ford F-150 Error Message: Wireless Connection Failed Screenshot 2025-05-14 172511
hammer58
hammer58
2022 F150 STX
Check your wifi settings on the phone. I have a Galaxy S22 and I found if I use the intelligent wifi and some other settings that would automatically connect to better wifi, as I drive by "available" networks I'd get drops. I turned that off and I no longer get drops. This may not be your issue but definitely helped me.
Thanks for the suggestion. I just checked my WIFI and intelligent wifi is turned off on my S22
