speedracercjr
Cory
2021 Lariat EB
O&G
If I remember right 22095 is Blue Cruise so you should be damn close now
JJ_Tex
Prosper, TX
2021 F150 Platinum Powerboost
Thanks all. I’ll pick back up later tonight and keep an eye on the sync versions.
BHunted1
Sumner County TN
Was my next reply above. Also in my signature
jordandev
Jordan
JJ_Tex
Prosper, TX
Ok, I think I need some help. In the software update, the only thing I have showing is GSM, which I have installed several times.
On the left side the GWM and APIM are both Orange indicating they have CMDTCs detected. What do I do to make them turn green? Screen shots are below.
Also I checked my Connected Services and Blue Cruise shows "Activation Pending". Hopefully I can get this resolved tonight before my 2 day license expires. Let me know if anyone knows what to do next.
Ford F-150 ECU module programming guide using FDRS 1651890970562
JEB
2021 F150 Lariat PB 502a
Go back to the vehicle identification page. Click on the blue tab that says CMDTCs in the center column. Then click on the tab that says “clear and retest.” See if the DTCs come back. If they do, post exactly which DTCs are showing up. If they’re communication errors, don’t worry about it. Drive around and they should clear on their own. If the errors are failure to configure, you might have to do a PMI to complete the configuration but I’m not sure I’d do it this close to expiration of your license unless you are prepared to renew.
RetroMan
Lee
Redlands Fl.
J1 2021 F150 PB Lariat 4X4 802A
Retail Video Games and Console Repair
I am right at the end as well but stuck with IPC USB update failure and can't get past it. Only option i have left to try is the can-bus but I will not have the time to try that till Sunday as its supposed to be about a 6 hour update thru the can-bus. So close but got to wait.
Ford F-150 ECU module programming guide using FDRS unnamed
JJ_Tex
Prosper, TX
Ok I did the clear and retest and those modules turned green and then a new APIM showed up so I ran that.
I have a new sync version and now hands free is an option. I think I’m done, right? You guys rock and helped a non techy person get through this with minimal blood sweat and tears!
Ford F-150 ECU module programming guide using FDRS 999B0833-BD60-4D7E-9F1E-ECAD5C4CACFA
Ford F-150 ECU module programming guide using FDRS FA5E3401-3913-4F80-8B2D-010E803D877E
JEB
Good. ”Clear and Retest” is a good trick to remember. It will frequently clear communications errors, which is a good bet when the GWM is showing errors. In addition, it’s a good way to wake up non-reporting modules and force them to report their status. You probably didn’t notice, but your PSCM was gray. I’ll bet ”clear and retest” turned that from gray to green as well.
JScaro
Georgia
2021 Ford F150 Lariat 501.5A
Beer Drinker
@JEB same thing happens with mine when I run a scan and haven't moved the steering wheel. If I move before a scan, it will show green.
Don't know if it's coincidence but it makes me feel better when it's green.
