bmac
Jacksonville, FL
2021 F-150 Platinum 3.5 Ecoboost
finally got the login issue fixed. It involved uninstalling FDRS and proactively logging in to Ford service with a new account and having it open in the background in Microsoft edge.
rugedraw
Javier
Miami
Auto Sales
Here is what I am getting this morning. Any help/suggestions?
Not really sure....I haven't come across this one. Were you able to get past it?
UNCGrad
Melissa
Clearwater, FL
2021 Ford F150 AMB Platinum 3.5 Ecoboost 6.5 bed
It's the last one on the list. The others went through fine this morning.
I thought if no one had any solutions I would just try again later or tomorrow.
rugedraw
Javier
Miami
Auto Sales
Might not be the last one. That's one of the modules that once updated may release more. I am pretty sure another one will pop up after that one.
Is the TCM showing green in FDRS? No codes in it?
You can try a PMI and when FDRS asks if it is the original module, select "no". It may not work, but it won't hurt.
I've had issues with updates going through and restarting the laptop completely has helped in the past to get through a pesky update.
rugedraw
Javier
Miami
Auto Sales
I am getting the exact error on the TCU also
Then it may be an issue on Ford's side. Maybe one of the guru's can chime in on the issue.
What Sync version does your truck say it is on?
@UNCGrad Same question.....what sync does your toruchscreen say you're on?
UNCGrad
Melissa
Clearwater, FL
When I'm looking at the screen and on the left are all the modules the TCU is green. I don't see a TCM one.
I restated the laptop and got the same error when I ran it again.
How do I run the PMI?
Briansk12
Brian
2021 F-150 PowerBoost
Been updating everything yesterday and today. Just installed the APIM update and then the TCU update showed up. Sync is 23291_Product Revision:1049
UNCGrad
Melissa
Clearwater, FL
23291 product revision 1049
rugedraw
Javier
Miami
Auto Sales
Sorry...I meant to say TCU.
Click the TCU icon on the left in the toolbox tab and then everything you can do to that module appears on the right. The PMI procedure is usually towards the bottom of the list.
The you both are at the latest Sync and that TCU update is the equivalent to OTA 6.4.0. Not sure what the issue is. That I know of, that update has not been a PITA to install unless something changed recently.
UNCGrad
Melissa
Clearwater, FL
I tried running the PMI and I got the module configuration has failed.
Jesse-Infotainment
Jesse
2024 F150 Lightning
