JEB
Ha! Now Ford has a problem. . . .I just received a notice yesterday that parts are now available for 21M08. I'm not experiencing the issue but received the notice.
THANK YOU!!I just received a notice yesterday that parts are now available for 21M08. I'm not experiencing the issue but received the notice.
Edit: attached some potato quality pics of the notice
So you mean power release + power close?So, I have looked at the Tailgate CSP. It also involves wiring. Its going to be a disaster. I already know it. Those of you with power release ONLY are the ones affected. If you have power Release and close your truck is not apart of this.
The wiring is a pretty big job. They have to run from BCM to taiilgate and populate pins into several SEVERAL connectors along that path. I even see a picture of a 1 1/2 inch hole saw drilling to the truck at some point. So, get ready for some issues. I cant fix those issues either because I cant remote in and control the tech to run the wiring correctly.
Be careful guys with this one. Thats all I can say.
Yes, if you have the power release and power close tailgate you are not affected.So you mean power release + power close?
I have power release only...I have to manually close it. So far I've not had a problem with power release.
How crucial is this CSP to do? Because based on what I'm reading, I definitely want no part in it unless my tailgate has a high chance of failing.
Only thing that worries me more than a tech with a laptop is a tech with a laptop and a hole saw. Thanks for the warning.Yes, if you have the power release and power close tailgate you are not affected.
Power release only is affected.
The urgency is something you have to decide. All I can really do is forwarn and tell you its not a simple update only it does involve a lot of wiring. I can already see the problems. I said the BC 21G01 was going to be a disaster. I was right. This will be jsut as bad but multiplied.
We will see. I hope I am wrong I really do
I’d be interested in seeing what you did. Several people have tried unbricking the BCM, including @Jesse-Infotainment, using a PMI and answering ”no” to original module and it hasn’t worked on the Powerboost. What did you do differently?I thought I had bricked mine today. I ordered all the stuff to do the updates when this thread was on about page 15 and was unaware of the BCM issue. I was able to run the module replace procedure and just said no when it asked if the old module was installed and thank god that brought it back to life. If anyone thinks that might save theirs I can send you a little better instructions as to what I did exactly.
By any chance did you make FORScan changes (e.g., double honk delete, Bambi, etc.) before updating or was the BCM configuration stock and unchanged?
