nicholsbradley
Bradley
Louisiana
2021 Ford F150 Platinum
Analyst
Same as me and I’m on BC now. You should have cameras in the sidebar without Forscan changes. That’s all I noticed different other than my BC option.
Man you get boarded in Houston you can always bring mine up to date. This truck hell on wheels trying to get BC. :)
Ahhhh, that's a good thing.
Thanks for giving me the good news. :)
JEB
US
2021 F150 Lariat PB 502a
Did you configure your Nano to operate at fixed baud rate? If so, what is it set at?
The Nano appears to be set to a fixed baud rate of 9600. @iceman77 tried to reset it a few times to a higher rate and it would always default back to 9600.
JEB
US
Uhm, I did that testing... :p
Ah, sorry. It’s getting hard to keep track of who tested what. I just remembered that you were the one who confirmed for me that the baud rate was fixed, which might explain the Nano’s difficulties with post-update tasks, like final configuration.
Jesse-Infotainment
Jesse
2024 F150 Lightning
Power running boards.. all I can find in workshop is to make sure they are set to auto. What Iwould suggest is turn off anything associated with PRB and then turn them back on. Ive had issues with Rain sense wipers where I had to turn them off and back on also my auto high beams,
As far as side loading.. I can load the firmware outside of FDRS. So I can load older firmware if need be
Ajzride
Automation
I gave up on the F-150 and stayed up all night doing the Mach-E. Finished about ten minutes ago. Installed every update in FDRS but my sync is still not current and no blue cruise.
No new updates for the truck either, will have to try and PMI the IPC again
I hate hate ford so bad I can’t see straight right now.
rpeterslll
Rob
Livonia, MI
2018 F150 Lariat FX4 Sport
IT Professional
Has anyone mentioned how long the TCU update takes after the vehicle restarts prompt? I've going on 30 minutes with it running and no prompt that it completed or to remove the USB yet. I haven't found any previous posts regarding the TCU update length. I'm not in any restart loop though.
Jesse-Infotainment
Jesse
2024 F150 Lightning
It can take a bit. Ive seen anywhere from 5mins to 30 mins and more. The good thing is if you are getting a message to restart that means the update stuck.. IF it never finishes you can select it was successful and FDRS will verify packages., I suggest when verifying to make sure the ignition has been on for a min before. If you get a fail that means the ignition wasnt on long enough and reverify.
Ajzride
Automation
One thing I noticed was that sometimes the prompt to remove the USB would open a half second before another prompt (data collection, 911 assist unavailable, etc) and that second prompt would clear the USB prompt.
It’s not as obvious on the F-150 but on the Mach e there is a ripple water animation with the USB updates that are not on any other pop up and it makes it obvious.
rpeterslll
Rob
Livonia, MI
IT Professional
thanks. After 30 minutes, I shut down the truck for a longer period and restarted it. It then completed the TCU Update and prompted to remove the USB, then on to another APMI
update.
One thing I learned is that the Sync will prompt to remove the USB eventually once completed. Removing it before hand will cause a failure.
So did your sync version go up as of last?
Yes
So it appears that us Powerboost'rs without Bluecruise do indeed receive the APIM and GWM update that triggers BC for the BC folks afterall. I wasn't expecting that.
