CaliF150
Most Expensive GAS State
2022 F150 SuperCrew STX 4x4 2.7 EcoBoost
Software Engineer
I done this before on my Ridgeline. Now with more experience I am able to do this on the F150 STX base seats. I already added Heat.
Now cooling. Switch will be added soon. But first I need to add fans under the butt as well 2 more
Products I used is a mixture of
Fans I am using are these
https://www.aliexpress.us/item/2255...t_main.15.632c18026vmKTr&gatewayAdapt=glo2usa
I have used these before with great success in my Honda Ridgeline.
https://www.aliexpress.us/item/2251..._list.0.0.5a3f1802vXf5mv&gatewayAdapt=glo2usa
I am using these for dispersing air through the seat.
https://www.aliexpress.us/item/2251...st_main.5.632c18026vmKTr&gatewayAdapt=glo2usa
and
Ford F-150 DIY cooled seats started IMG_2261
Ford F-150 DIY cooled seats started IMG_2262
CaliF150
CaliF150
Software Engineer
Hmm, can you share more about your seats?
More is coming. This is just a beginning of the project. But both front seats will have 4 fans. 2 for the back and 2 for the butt and they will be very cold. There are other air distribution channel and special air foam I added you dont see yet in the pics above.
Here is videos of what I have done in a 2022 Honda Ridgeline. Now sold.
Pictures as well
Ford F-150 DIY cooled seats started cooling knob 2
Ford F-150 DIY cooled seats started seatCoolin
JJSnell
JJSnell
CdA, ID
2022 F150 Platinum FX4 PB
Have to say I like it... Good work, good write up and special thanks for the direct links.
Nothing like clicking those cooling seats on a hot summers day.
jperry5835
2021 F-150 Hybrid Platinum
probably work better than factory. wondering now if I can change the fans on my platty and use the oem wires. Cooled seats is one thing I really miss from my Cadillac
amschind
Adam
'21 F150 SCrew 4x4 Powerboost
Physician
I'm curious if it would be possible to use the factory turn on wire from the climate control unit to run this thing.
parkerdog
Illinois
f150
How noisy are they? Is the factory seat cooler four fans? I've never heard a factory one run before.
jperry5835
factory seat cooler is like one squirrel caged fan that does little except hint at moving air
Rockman5159
Rocky
Marion SC
2021 ford f150 FX4
and
Nice job and not too pricey. I may look into thatr for my truck. Thanks for the pics and links.
powerboatr
North East Texas, Piney Woods
2024 F250 King Ranch Chrome
Retired Navy Senior Chief
i must have missed it
but did you carve out air channels in the seat foam, or was it already there?
thanks
CaliF150
CaliF150
Software Engineer
thanks
Ford Foam is like the thinnest least supportive foam I ever touched. So I ordered OEM foam from dealer just in case for this project and cut a proper hole. Then added more foam on top specifically designed to let air through.
scuba
Dallas, Texas
'22 F150 Lariat PB Mid Front Bench, 2013 E350 4x4
Nice work. I researched the %$# out of cooled seats last week shopping for my dad a minivan, and it turns out minivans still make-do with "ventilated"-only seats, even in the highest trims. I had forgotten that actual "cooled seats" were a big reason for my F150 (Lariat mid, I think). (They are loud and as someone said above, only 'hint' at coolness, but it's still cooler than ambient air, and we felt a big difference getting back into the cooled F150 between test driving a bunch of "ventilated"-only seats at 100 degrees.
In the process of my research I came across DIY write-up, which was on a Tacoma. There may not be the under-feet AC vents to tap into like in the Taco, but may generate ideas for those following htis thread.
https://www.tacomaworld.com/threads/mod-for-true-a-c-cooled-seats-katzkin-degreez-required.561766/
CaliF150
CaliF150
Software Engineer
that is freaking awesome. Thanks ! I will consider running air conditioner into my fan!
