CMR Module Purple
BarryT82
Barry
WV
2024 F-150 Platinum
USAF
I installed some updates today and the CMR module failed. I’ve tried PMI numerous times and it keeps failing near the end. Is there another way to restore the module?
BarryT82
BarryT82
Barry
WV
2024 F-150 Platinum
USAF
I thought that I had it fixed, but I was wrong.
Did you try rebooting the truck?
BarryT82
BarryT82
Barry
WV
2024 F-150 Platinum
USAF
Yes. It keeps going into battery save mode while it’s installing. I have a 20A charger on the battery, but it takes so long that it’s shutting down during the process. I ordered a Clore charger today that’ll be delivered Sunday. I’m hoping that fixes it.
JohnTrigger
MD
‘24 F-150 STX 2.7L SCREW
You definitely need a 20A POWER SUPPLY and not just a charger. I assume Clore you bought is the 20A power supply. I hope you didn‘t “brick“ the module when it shut down a few times during the interrupted updates.
Weird. I have a 15a that will run my truck indefinitely and the 5.0 the charger shuts off during updates until it it detects the batt lose a little charge. Guess they're not all built the same. Do you have another vehicle that can feed it a little more juice?
It's harder to brick the modules than just low voltage showing up.
JohnTrigger
MD
BarryT82, where do you have the negative cable of the charger attached? Directly on the battery’s negative terminal?
BarryT82
BarryT82
Barry
WV
2024 F-150 Platinum
USAF
I tried it on the ground wire going to the body and the post on top of the BMS. My local Napa has a Clore 2320 and I’m going to pick it up in an hour.
JohnTrigger
MD
OK, good, you do want it hooked up on the other side of the BMS sensor, which you evidently understand (not on the battery terminal directly). Hopefullly the Clore 2320 which is highly recommended here solves your problem of it shutting down during the update.
The Clore can show you battery voltage and capacity via toggle once you hook it up before you push the “on“ button. See what your battery is at as it sits now. If low, try letting the Clore charge the battery first to allow a “running start”, then start the FDRS update session with it in power supply mode.
JEB
2021 F150 Lariat PB 502a
Are you using a Mongoose? I have seen the CMR bricked using cheaper Chinese alternatives and if you are using one of these, you will probably need to get your hands on a Mongoose to fix it.
@BarryT82 This......can you confirm whether you are using a Mongoose?
Those topdon cables will brick just about any module you try and update w/ it
JEB
Agreed. Utter crap. I don’t know what cable he’s using—he won’t answer—but I suspect it’s that one.
BarryT82
BarryT82
Barry
WV
2024 F-150 Platinum
USAF
I’m using a VNCI cable. I’m out with family right now, but heading home to try the charger.
