CAI on 3.5 and 5.0 interchangeable?
TravisM
Travis
Effingham, IL
Ford F-150
Hello!
i bought a 5.0 CAI, thinking about going to the 3.5 powerboost. Will the CAI fit the v6? Looks like it was just wanted to ask
JExpedition07
James
Buffalo NY
2023 F-150 STX 5.0L V8
Likely not, the 5.0 has a larger throttle body (87 mm) and intake plenum as it consumes more CFM of air then the 3.5 EcoBoost. 5.0 TB is 87 mm, EcoBoost is only 68 mm, quite a different in size.
TravisM
TravisM
Travis
Effingham, IL
Ford F-150
Okay thank you I wasn’t positive but wanted a second option thank you
TheGoatman
22 powerboost
Consumes more CFM of air? Is that really true?
JExpedition07
James
Buffalo NY
Current generation 4 5.0L flows about 320 CFM, a factory 7.4L 454 flowed about 275 CFM on the best iron heads. Turns out spinning a 4-valve 5.0 liter up to 7,000 rpm takes a shit ton of air. CNC’d aftermarket 3.5 heads I have seen are around 315, I’d imagine stock they are in the upper 200’s like the 454.
EricR
Eric
Boise, ID
How much air does the 3.5L consume at 6250 RPM and both turbos pushing 20 PSI?
