Battery concerns when putting truck into summer storage
gkaz
Tucson
2023 F150 King Ranch
2023 K.R. 3.5 EB
We often go over to Europe during the summer for six months and leave the truck in storage.
With my 2014 I used to hang a solar trickle charger (battery tender 10 W) on the front grill, disconnect the positive battery lead, and then attach the solar trickle charger to the battery.
When we return and I reconnect the battery, the truck would start up as if it was run five minutes ago.
With this new truck and all the complicated BMS stuff I don’t know if that’s the way to do it or should I do something else.
Can I simply disconnect the positive lead, hook up the solar panel to the battery terminals (negative in the proper position on the BMS) and walk away?
When I return can I simply reconnect the positive and drive away or do I have to start fiddling with BMS resets, etc.?
Thanks in advance.
ReverendQ
Kevin
SoCal
Website
www.linkedin.com
I have hood solar hooked up on MY23 but longest I have gone is about 3 weeks in winter SoCal sun. I advise leaving everything connected and solar charge letting the BMS see it.
I'd look at a larger panel and leave everything connected.
gkaz
Tucson
I got a bigger panel, the battery tender 35 W and will hook it up so that the BMS sees it
