Android widget
kennelh
kennelh
Louise and Ken
Northern California
2021 Mustang Mach-E, Premium RWD
uhhh, the app notified me there was an update and I said yes, update. Is this now the bad version or a corrected version ?
edit: under settings it says it is version 2022.05.25 and it appears to be working...
If you see 2022.05.25, you're safe as well. I believe the bad version was 2022.05.25c.
PadU235
James
Kentucky
2021 F150 Lariat V8 Job 1, 2019 Escape Titanium
I took the auto 2022.05.25 update as well and it does appear tp be working. I do have a question. My OTA status has show unknown for some time now thru several updates. I have been using FDRS to receive updates and have not received one over the air from ford since November. Does the Ford OTA status info time out after a couple months of no updates or is there an issue with the widget?
kennelh
kennelh
Louise and Ken
Northern California
I've not confirmed this but others have said that the last OTA info only stays "live" for three months, then it disappears. That sounds like what you're seeing.
pavementends
Idaho
Enginerd
Hey @kennelh I allowed the update to broken version 2022.05.25c before I read your warning and my app broke. Your link in post #214 doesn't seem to work. Can you provide a link to download/sideload your 2022.05.30 version? THANK YOU ?
kennelh
kennelh
Louise and Ken
Northern California
Here is the link to 2022.05.30 (it's the same as 2022.05.25, just a later version number). It got pushed to a separate branch instead of the master branch.
jeffcrum
Lake Saint Louis, MO
Computer programmer
Thanks. That worked. I was getting a bad download searching on my own.
I seem too be GitHub impaired :p
kennelh
kennelh
Louise and Ken
Northern California
Version 2022.05.31 just uploaded. Notable in this release:
  • Ford Escape vehicles are now supported.
  • On EV/PHEV vehicles, a notification is sent when charging completes.
  • Android 9 devices can now save/restore settings, save log files, and save crash reports.
There is also an experimental feature (disabled by default) which will force vehicles to send an update if the last refresh is 6 or more hours old, as long as the vehicle is not in deep sleep and the 12V battery is at 13V or higher. NOTE: this may result in a drain on the 12V battery: use at your own risk.
I've also been working with a group of testers through the Play Store, and hopefully this version will also be available there shortly. Stay tuned.
mrnavy2
Steve
Central NJ
2024 Dark Horse Mustang, 2023 Roush F150 XLT
I just got a update notice of 2022.5.31. Is this safe to update?
mrnavy2
Steve
Central NJ
Shoebox72069
MN
2021 F150 Powerboost Lariat
If you need help testing the version through the playstore still, let me know otherwise I'll get this bad boy side loaded!
Roscopcoletrain
NS
22 F150 XLT...on order
for those of us who don't have an Powerboost, anyway to make that charger button next to the Fordpass a refresh button?
UGADawg96
JAX, FL
Anyone have luck getting the fordpass to update quicker ? While this widget is in fact updating as expected, when checking the fordpass app, it sometimes doesn't update for 12+ hours until a manual refresh forces it. I have both fordpass and this widget set to Not Optimized in battery settings on my Pixel 5a.
kennelh
kennelh
Louise and Ken
Northern California
Other forums have mentioned Ford's SSM 50804 (2013-2023 Various Vehicles - 12 Volt Battery Drain When Using Third Party Phone Applications- Modems Activated Through FordPass Or LincolnWay) which suggests avoiding frequent updates. The last version of the app has an experimental feature to force an update every six hours if necessary, but it's use at your own risk.
mrnavy2
Steve
Central NJ
Just received 2.7.1 update. Can someone tell me what changed?
Thank you
