Advanced Security Pack Removal?
BLWNBYU
MATT
MONTANA
23 502A PowerBoost 22 Camry AWD XSE 97 Cobra
INSPECTOR
Just got the Window sticker for my 502A to be built 12/03. It's showing start/stop, heated mirrors, and now Advanced Security Pack Removal. Yet another thing to be irritated about. I hadn't heard anything about removing the alarm system yet. Has anyone else had this yet?
Ford F-150 Advanced Security Pack Removal? Screenshot_20221123_222537_Driv
diambo4life
OKC
2022 Lariat Screw 4x4
Assassin
Why not attach the whole WS?
J17GT
Jason
IL
2023 Lariat 502a
Removed from my Lariat 502A as well. Was not aware of it until I got the window sticker. Stinks, but not a deal breaker for me.
F150 hopefull
oregon
I believe it is only the internal sensor alrm part. but I could be wrong. and it was removed from my build as well.
My truck was built today and is now awaiting shipment. My blend date was 11/22
Cheers
Buddy726
Joe
United state
2022 f150
My 23 just arrived at the deal and it is missing the advance security as well. Can this feature be added back? If so any part numbers.
astrand1
Alex
22 Ford F150 Powerboost 7.2kw
Studio truck driver
Where are the interior motion sensors located?
F150 hopefull
oregon
they are at the top next to where your rear window slider button is. here is a video I found that touches on it:
Just over 8 min into the vid.
DT400
Darrell
The key fob under the chin trick is pretty interesting.
Darrell
astrand1
Alex
Studio truck driver
Yeah I knew that’s where they were in the 13gen but I’ll have to look at mine. See if there is even room there. I have a little sensor looking thing in the plastic part that covers the camera and stuff on the windshield.
F150 hopefull
oregon
oh, shiet. didn't relize that was on a 2019. dang it.
Buddy726
Joe
United state
2022 f150
Turn the two sensors that they deleted be put back if you want them and probably have to be programmed does anybody know how and where even part numbers? Looks like you need a new overhead Consol.
Old Bear
Jerry
Clarksville, TN
2023 Ford F150 King Ranch Powerboost
Information Technology
Tasca Parts, but I know diddly about the installation. I suspect that I will be figuring it out though.
Buddy726
Joe
United state
2022 f150
no sure somewhere i read its in the overhead center console. not sure about the part you listed is that one of them?
Porpoise Hork
Bret
IT Sys Admin
Darrell
That trick has been around since aftermarket alarms first came out. The increased range you get doing it is pretty impressive.
I had looked into it for the 20 Ranger and found that it's fairly straight forward. The module plugs into the harness and mounts on the driver's side kick panel area. Some versions had a LED indicator that had to be snaked up and mounted in the top of the dash if you wanted it. Then there was some minor coding with FDRS or Forscan to make it all work correctly but don't remember the specifics. It's only about an hour shop time for the dealer to install it and can use your Ford points for it if you want.
