My glare free lights are working, very cool how they work. Thanks Robb!!!Enabled this on 22 KR today. Will try it out tonight.
If it was too bright out, auto-high/glare-free won't work. Not saying that's the problem, but could be. For me, if I can't easily see the light output, glare free and auto high doesn't do anything
Change to the following:I took possession of my 502A back in early February. I quickly switched over the appropriate codes to allow for the Glare Free headlamp possibilities and was amazed(Thanks again Robb). On the flip side I lost the back and forth capabilities that came with the truck. I also have a Check Headlamp System warning that pops up every time I start the truck.
Once again getting into this issue I notice that I have a CCM fault talking about an obstruction as well as an HCM fault telling me the indicator lamp is off. I have gone through the changes on multiple occasions to correct what Robb shared in post 8.
Any help would be greatly appreciated.
Not near my truck but in forscan but are there 4 digits in the second box? If so keep the last two digits in that box and only replace the first 2 with 4E.When I put 4E into the second box Forscan says incorrect format.
Grrr
Follow the contact us instructions here: https://forscan.org/contactus.htmlWell, I got everything to accept the change except for the IMPA... Service interruption. I'm uncertain of the procedure to get a test version or whatever it'll take to make that last change.
I have the OBDLinkEX and have updated drivers and firmware.
Are Job2 2022 trucks already on the road?Can anyone with a Job 2, 2022 (US Spec) truck chime in on the availability of Glare Free lights?
They are usually pretty quick. I’m sure you will be in good shape for the weekend.Thanks. Figured out what/how to send this afternoon. Losing the truck for spray-in bed tomorrow, so I have time for their response to finish the mod hopefully by the weekend.
