scott011422
The Forscan versionAre you asking about how to get a version of Forscan that allows you to write to all the modules if you are having issues?
Or how to do the glare free changes?
The first thing I would recommend doing before you ask them for help is do the minimum that they recommend you do first. That involves everything listed here, as well as purchasing and trying the recommended adapter (OBDLinkEX) with updated drivers and firmware (YouTube), as well as make sure you are using the latest released Forscan version.The Forscan version
That is a job 1 truck. Mine was blended 3/29/22 and I’m currently driving around with glare free rockin.Before I jump in with both feet I thought a read that Job 2 '22s are missing some hardware to allow these to work properly. Is this correct? My Platinum had a blend of 03/22. (Apologies but can't seem to find the answer via search.)
Is your truck Canadian?I have a 2022 F150 Lariat and it has the adaptive headlights directly from the factory. also it only has auto high beams.
Keep in mind the part changeover timing is based on the Job #2 CANADIAN trucks, which run on a slightly later schedule, but is right about now.Can anyone with a Job 2, 2022 (US Spec) truck chime in on the availability of Glare Free lights?
When it first comes on, it’s no different (at least to me) than when your regular high beams come on. At least as far as how they shine and light things up. However, the actual act of turning on is much more gradual and fluid. They don’t just *bang* turn on, the gradually ramp on.It was pretty much fully dark. It was only 4:45.
Checked all the settings, They were good. Went ahead and reset all affected modules.
I did notice in the manual it says the glare free only works above 32MPH, but i was well above that.
How exactly is it supposed to work? What am I supposed to see?
I'm assuming the high beams come on above 32 mph, and morph to not shine on oncoming or outgoing vehicles?
Normally on my way to work the auto high beams are always turning on and off, didnt see anything today.
