8" cluster swap IPC issues with FORScan
Finicky8157
Jacob
Alabama
2021 STX Screw
Attempting to upgrade my cluster to the 8" one from the 4". As-Built data came over fine, I can add boost gage to the new cluster. However, I cannot get the milage to update. The new cluster is brand new at 0.0Miles. Old milage is 33646. Any suggestions?
It will say IPC Odometer Write has been started
Current mileage:0 miles
Service procedure has been interrupted
When you run forscan, don't load your saved vehicle and try again allowing it to rescan all modules.
Finicky8157
Finicky8157
Jacob
Alabama
2021 STX Screw
Yeah I've tried that too. Had to do that to get the as built to load correctly. I'm about to try a different laptop. Tried 2 different obd cables
Are you trying a decimal? Never programmed mileage, try smaller increments.
Finicky8157
Finicky8157
Jacob
Alabama
2021 STX Screw
No, just going from 0miles to the 33464 my truck has.
AntimatterJoe
Joseph
2021 F-150 XLT rwd
Is Forscan up to date? If you’re using an older version that can sometimes cause processes to fail
Finicky8157
Finicky8157
Jacob
Alabama
2021 STX Screw
I ended up getting it fixed. Had to use a different cluster, I think it was because it was a 5.0 and not 3.5.
