6112 & 5100 combo
gambler1
Jerry
Central Florida
23 Platinum Rapid Red, 3.5, 4x4, Leveled. Tint
2023 Platinum Supercrew 3.5 ,Max tow , Fx4 .
Would Bilstein 6112 coilover on max 2.5 setting and 5100’s in the rear be a good combination
and improvement over factory suspension? Also will be putting 295/60/20 tires on stock rim.
Have a 2” puck on front now and I still have a lot of rake. I want it “near” level less rake.
What should I expect?
gambler1
gambler1
Jerry
Central Florida
Dang 140 views and 0 replies?
EcoB259
GB
22 XLT S Crew
Calson
Monterey CA
Better to go with Rancho XL adjustable shocks at the front and rear. Then you can adjust the amount of dampening you need. I used these on a 1-ton that would carry a 3700 lb slide-in camper and once I got the best setting for the front shocks I left them at that setting and for the rear I used a much higher setting when there was the load in the bed. It took less than a minute to adjust the two rear shocks. No porpoising and a softer ride when the bed was empty.
TheGoatman
22 powerboost
What’s an improvement over stock suspension? Need more detail than that. What kind of ride are you after?
you’re going to need to preload it all the way to get over 2”, but it’ll solve that issue.
gambler1
gambler1
Jerry
Central Florida
Planted, less roll / sway in turns, better steering response.
All why raising front end up and achieving less rake and better look without having to get a lift .
Gord0
Gordon
2021 Lariat 502a
I put Bilstein 6112/5160 combo on mine a couple weeks ago. They're a firmer ride than the stock FX4 shocks. The whole truck feels much more planted though. It also handles high speed bumps/washboard much better than the stock shocks. Adding heavier tires like you plan would make the Bilstein even a better choice. The 2.5" setting will get you pretty close to an exact level. I'm on the 2" and have .75-1" rake.
Heimy17
Jamie
Alberta, Canada
2023 F150 Lariat, 3.5 Eco, FX4, Black Pkg
Hi Gord0, do you have the max tow package? I'm just wondering if that will leave more rake....
Gord0
Gordon
2021 Lariat 502a
I do not, but I don't believe it will add any more rake. I didn't think the max tow had more rake than the standard, just "upgraded" leafs in the rear, among a few other things.
Heimy17
Jamie
Alberta, Canada
Fair enough, thanks for the reply! Cheers
gambler1
gambler1
Jerry
Central Florida
I have the Max tow and believe it has a little more rake tha than
the non Max tow. With a 2” puck in the front I have 39 1/2 fender height and rear 41 1/2 SMH.. Bilsteins going on Friday so we’ll see the difference then.
Heimy17
Jamie
Alberta, Canada
Sound good, keep us posted. I have my 6112's/5160's on the way and am interested to see your final measurements.
crazywayne311
Wayne
Hampton Roads, VA
CTMO
an almost apples to oranges comparison but i have the ford performance bilsteins...huge difference over stock FX4. Definitely feels more planted, definitely less body roll and rides great. no complaints
gambler1
gambler1
Jerry
Central Florida
I’m exited to get them on. What tires and wheels are you running?
I’m staying on a stock +44 wheel and going up to a 295/60/20 tire but torn between Toyo,Nitto, Bfg, Faulken. Too much info. Brain overload for sure.
gambler1
gambler1
Jerry
Central Florida
Bilsteins on 6112/5100 and 295/60/20 Nitto today. Not many miles yet but I am very pleased so far. 41 1/4” rear 40 3/4” front. With improved handling.
Ford F-150 6112 & 5100 combo IMG_1273
Ford F-150 6112 & 5100 combo IMG_1279
