36 Gallon Fuel Tank
SilverPigeon
Australia
In proper units, the 36 gal tank is 136 litres. I just put 122 in it, so I had 14 litres (3.7 US gal.)left; that would have got me 113 kms (at 12.3l/100km, or 70.7mi @ 19.12mpg) further down the road before using the fuel in the pipes ?
p.s., I did the conversion to arcane units because I know how lazy you all are ?
gagliano7
Joe
Monroe NY
You also have to remember the tank is long so a gallon of gas in the tank would probably be tough for the fuel pump to pickup the fuel especially while driving and fuel sloshing around.
thebestbear
Ted
Boston
2021 F-150 STX
Contactor
I run my tanks to zero when I first get them so I know what I'm dealing with. I did run my 36 gal. tank down to 0 in the city flats and was able to fill up with 34.49 gallons.
However...
When I parked on a hill facing upwards, I drove up and parked, but when it came time to leave the next day, the truck would not start because no gas. I was only able to get 32.76 gallons in it that time. Almost 2 gallons difference when facing uphill. The deal is the pickups can't get the gas when going uphill, but the system lines hold enough to keep the truck going for a bit until you get level again while driving. Moral of the story? Don't park facing uphill if your on E
Eighthtry
Boyd
Heath, TX
2021 Lariat SuperCab 5.0
Thanks everyone. This will give my dealer something to work on.
Groovicles
2022 F150 XLT 302A PB Max Tow
Finance
I have a neighborhood question for a 36 gallon tank, 2023 F150 XLT 5.0. Despite driving it down to low "miles left" (as in 38 today), I can only fill to a max of 30 gallons. 100% of the time. Never 31 gallons. No matter how hard I try. This includes the slowest tank hand feeding after it clicks off at 30 gallons. It eventually runs over despite how slow the fuel is delivered, but never exceeds the 30 gallon range.
When I get in to drive off it shows a new range of, for example, 621 miles today, which works out to 17.25 mpg when divided by 36 gallons. I average 18.2 on the dash.
So, by throwing dog vomit on the wall my 30 gallon fill seems to be in the neighborhood of 17.5 mpg using 36 gallon capacity. My average is 18.2 on the dash. So I think the 17.5 mpg is a reasonable number, after examining the dog vomit.
I have never encountered this on a vehicle. I have probably owned 20 or more in my 71 years. If it said a 22 gallon tank, that is what it held, etc.
To sum, 621 range miles divided by 36 gallon capacity averages 17.5 mpg. I am averaging 18.2 according to to the dash. But still cannot get more than 30 gallons in refill.
621 miles divided by 30 gallons is 20.7 mpg, which is nowhere near the real world 18.2.
So, what am I missing? I haven't asked the dealer since I doubt I would get a knowledgeable answer. I am not even sure how to frame the question yet.
So far I have never filled at the same gas station so there appears to be some consistency in the numbers. No one is charging me for 30 gallons but delivering 35 gallons.
Is this making sense to anyone? It's giving me a headache, as is having to read dog vomit on the wall.
Otherwise it does not appear to affect me much. Just bumfuzzled.
Are you sure the dealership didn't just give you a PB and just changed the badging? ?
It is possible, but unlikely, that your calibration is off on the tank. I doubt the dealer will bother fixing such things but if you have a good relationship maybe they will look into it.
haroldyoung550
Harold
NYC
2023 F150 XLT
Ford has had the same tank forever.
Older generation had issues parked on hill low fuel couldn't pick it up.
Ford fix was software change leave larger reserve never be in situation where your truck can't pick up the fuel.
You can drive well past 0 miles to empty. Just don't park on any hills. :)
I routinely hit 0 and put in 32 gallons, many of us do. It's a well known feature on this generation.
Still better than the smaller tank offered even with the wasted space.
Do you know if the 2015-2020 36 gallon tanks will fit on a 2021+ F150? Are they the same tank?
powerboatr
North East Texas, Piney Woods
2024 F250 King Ranch Chrome
Retired Navy Senior Chief
I would not be surprised
If it s the same
The frame has not changed in long time.
Ford saves money like the others by using many same components through out model lines
Calson
Monterey CA
Two different threads in this post. Does the tank hold 36 gallons of fuel and secondly is the miles to empty information from the computer accurate. I always have figured that the last two gallons were not to be relied upon and make fuel stops accordingly.
Yesterday the fuel gauge on my truck showed 3/4 of a tank and I added 12 gallons of gas to the tank. At the 3/4 market the tank should have required only 9 gallons to fill it up so the gauge is an approximate indication of the actual amount of fuel that is in the tank.
Pr0sacK
Stefan
Wisconsin
2021 F-150 Lariat
The last couple of tanks (36 gallon) I have driven like a grandfather. Eco mode on the interstate, adaptive cruise set at +3 for tolerance based on speed limit signs. I've been hovering around 24.5-25 MPG. I just think its fun to fill it up and see it say 850 DTE even though I know it will be more like 730 miles or so. Now that the experiment is over, I'll go back to driving it normally. I didn't buy it for fuel economy after all ?
Kanuck
Winnipeg, Manitoba
Retired Electrician
Drove around town yesterday, filled up...started out at 1125km DTE, drove home on the highway, about 15 km, truck said 1127 DTE. Driving faster adds fuel in your tank...:crackup::crackup::crackup:
Jimko
Jim
Montpelier VA
2023 F150 XLT 302A SuperCrew, 2023 Ford Explorer
Senior Systems Engineer
I don't think is is uncommon at all. I traded at 2022 Jeep Gladiator in on my 2023 F150. The Gladiator has a 22 gallon truck. However even when my low fuel indicator said I had like 10 mile to empty, I was only ever able to put in 17-18 gallons.
Flounder
Pennsylvania
Tremor 402A
My 2017 was not programmed for a significant reserve. I could run it down to 0 miles to empty, plus a little more, and fill it in the range of 34 or so gallons. I think the most I ever filled it was about 34.5.
My 2024 is programmed for a significant reserve of at least 4-5 gallons, albeit the miles to empty depends on past driving habits. I decided to test it today, out of curiosity. With one mile to empty, it took 32.275 gallons. On the way to the pump, taking curves, etc., there was no stuttering or other indications that it was actually at drips of gas left. My guess is that at 0 miles to empty, you have about 26-40 more miles of travel left. Of course, when you run out of gas in the middle of a desert because you are reading this, don't blame me.
One other observation -- because of the reserve, the best I can do with the 2024, based on the gauges, is about 600 or 625 miles to a tank. With the 2017, I could exceed 700, but only by a couple miles. The difference is the reserve.
Ford F-150 36 Gallon Fuel Tank IMG_6641
Ford F-150 36 Gallon Fuel Tank IMG_6644
Ford F-150 36 Gallon Fuel Tank IMG_6643
Eighthtry
Boyd
Heath, TX
So that is an infamous Foreskin edit?
