SALEEN961
- Joined
- Jan 1, 2023
- Threads
- 12
- Messages
- 653
- Reaction score
- 876
- Location
- Radnor, PA
- Vehicles
- 2021 F150 XLT 302A
- Occupation
- Automotive Technician
I've been dealing with false knock on cylinders #1 and #3 for a while now, and it has been an issue both stock and tuned. It's easiest to duplicate around 2000-3000RPM at 0.3-0.6 load, but I occasionally see it at WOT too. When it occurs, I see cylinders #1 and #3 pull 3-5° of spark while the other four cylinders are sitting at 0KR or adding timing. Removing 5°,10°, or 15° of spark makes no difference, increasing the DI blend doesn't help, 100oct fuel didn't help, and running E50 hasn't made any difference either.
I'm not seeing anything loose that would cause false knock, but I recently started hearing a rattling/grinding noise that coincidences with the false knock now that it has gotten slightly worse. The noise seems to be coming from the area around the passenger side catalytic converters and turbocharger, but it's very hard to pinpoint as the noise resonates through the exhaust system.
I pulled the cats out of my truck and ran a borescope through them, no damage or anything unusual was observed, the heat shields are tightly clamped, and there are no signs of anything rubbing or hitting that I've been able to find. Both turbos seem fine and have the same minor amount of play in the wastegates that you would expect to see.
After reassembling everything and making sure every nut and bolt is tight, the noise and knock are both still there. I tried adding additional clamps to all the heatshields and peening around the catalyst material on the passenger side to hold it in place more securely, but it didn't help. I'd really appreciate some advice from anyone else who has run into false knock on their 3.5EB, particularly if you found something unusual on the passenger side of your truck. I'm tempted to completely replace the cats just to rule them out. I really don't want to spend $2,300 on something that isn't a guaranteed fix, but I'm also tired of waiting for the problem to get worse.
2021 F150 3.5EB 4WD with only 19K miles.
Pics from this weekend:
