2021 PB engine barely runs for the first few seconds when cranked
tmark
Thomas
2021 F150 King Ranch powerboost
Occasionally, my '21 PB (88k miles)shakes and shudders for the first few seconds after starting up, as if starved for fuel. I can pat the accelerator gently and it catches up and runs fine. Once I had it shut back off with the dreaded message of pull over and stop asap or whatever that one is. I could not restart for a while, as it was unresponsive to the start button. I was stranded in a store parking lot in the hot sun. Not a happy camper! Is this a known issue?
madsend81
East San Diego County, CA
2023 F150 PB XLT Sport 4x4, 157" WB
Rule out the usual suspects: air filter, MAF sensor clean, throttle valve clean, fuel injectors clean, etc.
FaaWrenchBndr
Denver, IN
‘24 XLT Powerboost
No check engine light?
Bad fuel?
Change spark plugs?
Wet air filter?
It’s not a new truck, 88k miles things happen. How long has it been doing this? May want to take a picture of the message if you can’t remember it. Does it do this on every start or just a cold start or a hot start?
tmark
Thomas
Bad fuel?
Change spark plugs?
Wet air filter?
It has done it on a hot start a few times. Only once did it throw a light and warning and refuse to start for a few minutes.
FaaWrenchBndr
Denver, IN
‘24 XLT Powerboost
So it does it now and then but not all the time.
tmark
Thomas
Correct. It happens once every couple of months. I was just wondering has anyone else experienced the same thing. The PB seems to be buggy in the electronics, with other things happening as well. Running boards don't always deploy properly. The A/C has conked out a couple of times and reset itself after a restart, plus this rough start issue.
FaaWrenchBndr
Denver, IN
‘24 XLT Powerboost
I haven’t heard of any issues like that. I’m sure others will be around and chime in over the next few days
Once every couple of months........
That pretty much throws out anything that I could have considered. I'd be looking for commonalities between each occasion. What appears to be random often isn't as random as it appears.
  • Like
Reactions: STM
