adamh77
adam
south Arkansas
2025 Ford f 150 stx 4x4 5.0l
e/i tech
im new here but i just bought a 2025 f 150 with the 5.0 and im looking for help as my cable will be here today
looking for the sheets and helpful knowlege on using forscan for first time
digitaltrucker
Ed
2021 F150 Platinum, 2013 F150 Lariat, 2008 F150 Lariat, 2005 XLT, 89 F150 Lariat
Post number 1
ok thank you
I would also look up some YouTube tutorials on FORScan. Personally, I learn better by watching it being it done in real time than reading a tutorial. Just go slow, start with something easy and document what is there (or make a back-up) before you change anything jic.
adamh77
adam
south Arkansas
e/i tech
i was going to start with the bambi and auto start /stop
adamh77
adam
south Arkansas
e/i tech
ok i tried bambi and start ,stop
and only thing working is start stop and now i have the battery light on
Is Bambi mode working?
Paul Neubauer
Paul
I always take a picture of the screen before I make any change to a line. I have accidentally changed the wrong line before and having a picture made it easy to see what I did wrong and put it back before changing the correct entry. I also write down every entry I change with the before and after as a record.
SilverPigeon
Australia
i have a charging system fault now
1. Are you doing FORScan with the truck running?
2. If not, what does the voltage read at the bottom right of the FORScan window?
3. If voltage is below 12V, you will start to have problems with modules reaching low voltage and going silly. Charge the battery and if possible put a charger in power supply mode on the battery.
4. If you can't do no. 3 and you still can't get a decent voltage, start the truck and go for a ½ hour drive on the highway to charge it up before resuming a FORScan session.
5. If you can't get the battery charged up to at least 12.3V, most module configuration can be done with the truck engine running. Modules I would not do in this way: PCM, GWM and any module reboots in service procedures.
Revert the changes you made to what was there before. Did you make a back up or take a pic? If not, send me the VIN and I'll pull the data from Ford.
amkaras
Austin
SW Iowa
2021 F150 Powerstroke Platinum
You are describing lane centering as your "want to have". Lane keeping with aid is the "bounce between lines". Bluecruise is hands off the wheel on certain roads. If you're wanting lane centering , the 8 stays, don't change to A. When you engage adaptive cruise control, the "hands on the wheel" should display. Have you verified your settings on the Sync screen Features>Driver Assistance>Cruise Control"? Adaptive and lane centering enabled?
Not knowing your original state of configuration of the truck, and considering you have seemingly made changes to or had problems with the TCM, My advice would be back out of all FORScan changes you have ever made in every module you've made them. You may want to talk with @rugedraw before doing so. In the meantime, and if not already done:
1. Clear and rescan DTCs
2. Reboot the following modules: SCCM, IPMA, TCM, PACM
3. Clear and rescan DTCs.
Let us know the current state of play after that.
I changed to the glare free in the SCCM and all is well now. Thanks again for the help. Does disabling the active air dam set any codes?
SilverPigeon
Australia
@amkaras I haven't tried it. In lieu of some other input, go for a drive on the highway and then rescan DTCs in FORScan. That will tell you.
bgalakazam
Lubo
Colorado Springs
2021 F150 500A Lariat 4x4 5.0L 3.31
Can some of the Forscan gurus help out again? I finally have time and park truck near the house.
Issue 1:
I added a heated steering wheel few years back. I upgraded the HVAC module to have the heated steering button. Everything works fine, but I cannot get rid of the error:
Code:
HVAC U2420 Not Programmed
I have reloaded the as-built from my old module, didn't solve it.
;Block 1
733G1G10076C1DC1463
733G1G25A11E7718383
733G1G366006E503698
733G1G40A506E50368D
733G1G552128268008E
733G1G6E30E204420B6
733G1G7F440CA70B060
733G1G80281A00080E6
733G1G9200000000064
733G1GA00000000004B
733G1GB00000000004C
733G1GC00000000004D
733G1GD000000004E
;Block 2
733G2G13146544657A5
733G2G2314535384D6E
733G2G3464331343461
733G2G43832AA
;Block 1
733G1G10076C1DC1463
733G1G25A19E771838B
733G1G366006E503698
733G1G40A506E50368D
733G1G552128268008E
733G1G6E30E204420B6
733G1G7F440CA70B060
733G1G80281A00080E6
733G1G9200000000064
733G1GA00000000004B
733G1GB00000000004C
733G1GC00000000004D
733G1GD000000004E
;Block 2
733G2G13146544657A5
733G2G2314535384D6E
733G2G3464331343461
733G2G43832AA
Issue 2:
When swapping the steering wheel, I didn't keep my old left side buttons module (wheel sold). As a result, I had to make the change to get buttons to work:
Ford F-150 2021+ F-150 FORScan List / Database / Spreadsheet 1759199277235-1o
Ford F-150 2021+ F-150 FORScan List / Database / Spreadsheet 1759199263992-am
Now there is an SCCM uneraseable error for Bus communication. Probably due to the adaptive cruise button and the distance button. I don't use the distance button and regular cruise control works.
Is this fixable via Forscan or do I need to get my old module equivalent back?
Thanks.
