rugedraw
Javier
Miami
Auto Sales
Update: I went back to the default and now the buttons work, but I do not have blue cruise or highway assist availble to me now. I still have the SCCM DTC for configuration incompatible as well. I have rebooted the SCCM module a few times and cleared codes but it hasn't helped so far.
What codes is it reporting now? Does lane centering work? What do you show in ipma line 706-01-01?
amkaras
Austin
SW Iowa
2021 F150 Powerstroke Platinum
Yes, the HVAC DTC is not related.
Take a current backup of the SCCM, rename it by adding .txt to the end and attach it here. Do the same for the original one you backed up before you started doing any FORScan changes and I'll do a compare if you want to see what can be done.
Here they are. I uploaded the original file and the buttons work but no blue cruise or highway assist. I do have lane keeping.
amkaras
Austin
SW Iowa
U2101:00-2A. Yes, lane centering works. 8A58A2198E3A. I have attached 3 IPMS files. The oldest one is my default, the second oldest is config from the day I worked on the TCM error with you, and the third is the one I just pulled. I have a bunch of changes from the spreadsheet as a heads up.
SilverPigeon
Australia
The two files are different. I presume you have active steering on the truck? it was originally enabled but currently disabled. In asbuilt configuration, change:
724-01-01 xxx* xxxx -- from 4 to 8. My truck without AFS has 0 there. "4" is not a valid choice.
Also, 724-04-01 xxx* xxxx -- deals with what the SCCM knows about Auto High Beam (AHB). Yours was originally set to 2 (normal AHB) You have it set to 4 (I presume Adaptive Driving Beam), but 3 is Glare Free High Beam. I would advise that, if you have made other changes to have Glare Free enabled, that you change from 4 to 3; otherwise change it back to the original 2. Looking at my non-BC truck without Glare Free configured, I have 2 there. I have the same projector LEDs as you, but configured for normal AHB.
Either or both of the above could cause the invalid configuration DTC.
SilverPigeon
Australia
Also, in your IPMA with what @rugedraw asked you for:
706-01-01 xxxx xxxx *x--, you have 8 which disables Highway Assist (Bluecruise). change the 8 to A.
amkaras
Austin
SW Iowa
The two files are different. I presume you have active steering on the truck? it was originally enabled but currently disabled. In asbuilt configuration, chsange:
Also, 724-04-01 xxx* xxxx -- deals with what the SCCM knows about Auto High Beam (AHB). Yours was originally set to 2 (normal AHB) You have it set to 4 (I presume Auto Dynamic Beam), but 3 is Glare Free High Beam. I would advise that, if you have made other changes to have Glare Free enabled, that you change from 4 to 3; otherwise change it back to the original 2. Looking at my non-BC truck without Glare Free configured, I have 2 there. I have the same projector LEDs as you, but configured for normal AHB.
It does have active steering and I am running the other changes for glare free. 724-01-01 is currently 8 as that is what it was in my default file. I pulled the SCCM file, and then went back to my factory settings sheet I had saved as advised. It fixed the buttons, but I still have the code with no active driving available. I also changed 04-01 back to 2 for the sake of starting from scratch. The only other change that the default file made that I could find after the fact was 724-04-01 xxxx-xxxx xC to xA.
amkaras
Austin
SW Iowa
I think that was part of what snakebitten had used to disable the in cab camera. So I gave up bluecruise, but kept highway driving assist with hands on driving with no nanny warnings for looking away. I may be misremembering it and I can't find the thread offhand. But even after I made those changes I had hands on highway assist with no DTC.
SilverPigeon
Australia
...The only other change that the default file made that I could find after the fact was 724-04-01 xxxx-xxxx xC to xA.
That is an automatically generated checksum from FORScan; it is not relevant. Are you,saying that you still have the SCCM invalid configuration DTC? What DTCs do you currently have?
amkaras
Austin
SW Iowa
I found the picture from the thread I used as reference. I made it exactly like this and left the last 2 digits alone.
Ford F-150 2021+ F-150 FORScan List / Database / Spreadsheet IMG_5957
amkaras
Austin
SW Iowa
Yes, I am saying that I still have the U2101 error even after changing everything back to factory. Could it be that I still have the other glare free changes made in all the other modules?
SilverPigeon
Australia
If you want bluecruise, which you said you did, it needs to be A. If you only want lane centering, it's 8.
amkaras
Austin
SW Iowa
Okay, thank you. I want it to do the hands on the steering wheel but steering itself mode...more than just the bumping from side to side off the lane markings. It should show a picture of the steering wheel with hands on it and I don't have that. It was always tied with bluecruise before, but I am not sure what to call that mode. I see that the highway assist is also set to off (xxxx-xxxx-8x), but it has been for a whiile before this and was working to do the steering like when bluecruise road is not available. I will probably change it back tomorrow, but would like to have it back to the way it was before this code stuff if possible.
SilverPigeon
Australia
Yes, at least in the IPMA you do. Change it to 3 as previously mentioned for GFHB.
SilverPigeon
Australia
You are describing lane centering as your "want to have". Lane keeping with aid is the "bounce between lines". Bluecruise is hands off the wheel on certain roads. If you're wanting lane centering , the 8 stays, don't change to A. When you engage adaptive cruise control, the "hands on the wheel" should display. Have you verified your settings on the Sync screen Features>Driver Assistance>Cruise Control"? Adaptive and lane centering enabled?
Not knowing your original state of configuration of the truck, and considering you have seemingly made changes to or had problems with the TCM, My advice would be back out of all FORScan changes you have ever made in every module you've made them. You may want to talk with @rugedraw before doing so. In the meantime, and if not already done:
1. Clear and rescan DTCs
2. Reboot the following modules: SCCM, IPMA, TCM, PACM
3. Clear and rescan DTCs.
Let us know the current state of play after that.
